Harley Benton Les Paul style kit
I've just completed the build of a Harley Benton Les Paul style kit. Overall, I'm very happy with the result which represents fantastic value for money.
However, there is one minor problem. The bolt on neck is raised compared to a real Les Paul, and is at a different angle. The edge of the neck binding should be level with the top of the body, but is between 0.5 and 0.8 cm higher than this. Has anyone built this kit and experienced similar issues with the neck? Is it worth trimming the underside of the neck so that the fit is similar to the original Les Paul?
  • Adam_MDAdam_MD Frets: 3420
    Can you show us a better angle of the neck/body join?
  • The guitar kit at the top and my Les Paul Studio below.
  • WezVWezV Frets: 16730
    Its just because its bolt-on and it looks like they have gone for zero neck angle
    you could trim and angle the bottom, or the neck pocket, but you need to make sure the strings still end up at the bridge at the same place so it can be a tricky job if you have not done it before
    personally, for the rpice of the kit and the fact it will still be bolt-on I would just live with it
  • WezV - thanks for your comment.
    I built this (and a Tele before it) to learn a bit about building guitars before trying something more complex. So, for the experience, I probably will trim the angle at the bottom.
    I just wondered if anyone else had done this before and had some words of wisdom for me (like "don't do it"!).
    you will also need to plug and redrill the holes in the neck as they will all be at the wrong angle, and make sure the screws are not too long before you put them back in
    I would probably alter it by deepening and angling the neck pocket rather than the neck itself - but it all depends on the thickness of wood  you have available on both parts
  • JetfireJetfire Frets: 1696
    Did it come painted like that? Lovely finish!
    No, all my own work. Thanks!
    Looks great.
  • I decided to make the adjustment by sanding the base of the neck. The slight change in angle thankfully wasn't enough to force me to fill and redrill the holes. After adjustment intonation and action are fine (as before).
  • Glad you got away with it :)
    FWIW the "after" pic looks a lot neater
  • ChalkyChalky Frets: 6811
    Agree - fine work!
  • RaymondLinRaymondLin Frets: 11879
    Nice work !
  • hotpothotpot Frets: 846
    That's a great looking build, very cool work around with the neck.
  • OctahedronOctahedron Frets: 400
    What pickups did you use? :)
    Music the great communicator, use two sticks to make it in the nature - a music reviews blog: http://usetwosticks.wordpress.com/
  • For now it has the original Harley Benton electrics. The pickups are ok (actually very good considering that the kit cost about the same as a single Gibson humbucker!), but the pots are rubbish (1 and 2 is off, 3 through 10 is on - with no discernible change as you turn the volume knob). I'll play it for a while and decide what needs to be upgraded - so possibly go for Jimmy Page wiring and a set of classic blues humbuckers.
  • I eventually got fed up with the pick-ups that came with the kit, so replaced them with Iron Gear Dirty Torque and Blues Engine humbuckers, connected with Jimmy Page wiring using push-push pots. I took the opportunity to replace most of the mechanical components with black ones, and stained the back black.
    I used push-push rather than push-pull pots as an hour into a band practice my fingers are too sweaty to get a good grip on a pull pot. There are various pictures on the internet of very neat wiring for the Jimmy Page setup. My wiring, however, looks a bit like a sheep's entrails - but, much to my surprise, it worked first time. The variation in sound options that this setup gives you, combined with the Iron Gear pick-ups, is impressive. I love the tone of both pick-ups with split coil, in series and reverse phase (i.e. all pot switches in out position).
    The black covers I bought annoyingly didn't quite fit. Having adjusted the neck pocket (see earlier post) so that the neck angle is similar to a real Les Paul, I can't quite get the intonation absolutely perfect. But that's a big job for a small gain, so can wait.
