You can use a fret file to take the unevenness out (expensive beasts!), and this is often requiring a trained tech if a complete neck needing attention. However, if this is only now coming to light, it probably is only the slightest of passes of a file or pumice stone to flatten out the rogue fretwire... Worth a looksie...
However because it has been sanded, it may then be too low compared to the rest of the board and so it may need the rest of the frets dressing to suit it.
