Jet City JCA20HV biasing question
not_the_djnot_the_dj Frets: 7306
Picked up one of these yesterdays (from the classifieds here), very impressed so far.
I've just downloaded the manual and it seems to be contradicting itself with regards to the need to bias it when changing valves.
It states: JCA20HV is a Fixed-bias amp which allows you to “plug and play” EL84 power tubes without needing a bias adjustment.
But then also: ·       Class A/B, Fixed Bias (Internally Adjustable)
I thought that a fixed bias amp was the sort that needed biasing when changing power valves.
@ICBM are you familiar with these?
  • That's...disappointing. From what I know, they do have to be rebiased when you change valves - as do all their other amps.
    <space for hire>
  • Picked up one of these yesterdays (from the classifieds here), very impressed so far.
    I think the adjustment may just be to make it hotter or colder rather than a necessary adjustment.
  • OK, just had this back from Doug @ Jet City:
    Doug said:
    Hi buddy.
    You do NOT need to adjust the bias on the amp when you change the power tubes!
     D.
    <space for hire>
    Doug said:
    Hi buddy.
     D.
    Great, thanks for checking.
  • digitalscreamdigitalscream Frets: 26631
    edited November 2015
    No worries. I'm now sorely tempted by a pair of Mesa EL84s. £30 for a pair seems like a decent deal, given that I'm used to paying £20+ each for 6L6s.
    <space for hire>
