Polara gets you into similar territory as the Darkstar.
TC Electronic Trinity 2 is also a good contender. Approx £80 lightly used. I had one, loved it. Tone print was also a useful feature to add a 'regular' reverb.
M
I sold one as I needed the cash and it's one of those pedals that I've regret letting go ever since.
I WILL buy another one day!
From what I've heard, it is VERY similar to the Caroline Meteore, which I'd love to try out firsthand.
Best 'budget' verb I've heard is the Hardwire Supernatural. The Mr Black Supermoon can get some crazy sounds if a tad limitied. Subdecay Super Spring Theory has Trails and a Room verb setting for decent moneys.
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
Watched lots of demos and so on.
Just ordered the Darkstar. Looks like the kind of thing I'm into soundwise. It should also sit well with my other pedals:
EHX memory man with hazarai,
Gravitas,
Gunshot,
Bass Big Muff,
Industrialectric 4046-M.
With the Darkstar, should be lots of sounds in there. Thanks again folks.
I use a Supermoon chrome for the modulation. There are some really bent sounds in there. And there's another limited version of the Supermoon called Bloodmoon coming too.
The reverb on my Dr.Scientist BitQuest is amazing. I actually prefer the reverb on that to the Supermoon. I prefer the brighter voicing. It also has sick modulation and infinite reverb that will canabilize into mucky gooey entrails. It has a billion other sounds too and is within budget. Love this pedal.
The Catalinbread Talisman is just heads and shoulders above every reverb pedal I've played. It has a buffered mode so it continues when off. It has a pre-delay and clean boost. An amazing high pass filter which means you can set incredibly clean and natural reverb sounds. It introduces some very minor reflections, degredation and very slight modulation at the very end of the tails decay.
I did go for the Darkstar and used it a bit now. Very pleased with it. It's great actually.
Glad of your suggestions though.
Both brilliant, but different.
