I‘ve built a bunch of guitars from kits and renovated a few old ones, but I decided it was time to have a go at building a guitar from blocks of wood. I had no previous experience designing guitars or working with woodworking power tools, so I started with the Bailey Guitars on-line Design and Build courses. Check it out at guitarmaking.co.uk
The design course was very clear and I soon had my plan drawn up. My first thought was to follow the course exactly and build a standard Bailey Bandsman, but after trying several styles I decided to enlarge the body slightly and go for a single cut design.
This gave me the chance to make a few mistakes on replaceable MDF rather than lumps of mahogany or ash.
The most important tool in my workshop is my iPad, where Mark can show me what to do while I'm doing it.
Or too many times to count
Instagram
I then started work on the body template, only to realise that my design was a single cut rather than the double cut design that was the subject of the on-line course - and I wasn't sure how to connect the neck to the body. I decided to play it safe and go with a double cut design, which soon resulted in this...
It only looked like 5 minutes work to finish the job :-) but I'd had enough scary moments with my router and bandsaw, so I decided to leave the rest of the build for another day.
It generally takes 6 (very) full days of working in the Bailey workshop to produce a guitar, and that's with Mark there to advise & guide, so there's very little wasted time in those full days. If you carry on at this rate, you'll be finished more quickly than that ...
This was after the first, shallow rout of the pickup cavities, which looks good and lulled me into a false sense of security.
Routing deeper (after the neck pocket had been routed) didn't go quite as well :-(
The control cavaity, and the cover I rescued from scrap, have worked out ok.
Final job of the day was rounding off the edges with a special router bit. Although it was a success, I realised I should have waited as I plan to have both elbow and belly carves. On top of that, I feel that every moment with the router in my hands is one moment closer to a destroyed guitar - and I could have achieved the result with half an hour's sanding.
It looks like the template moved? How are you fixing the template to the body?
I mostly fix templates using masking tape on both surfaces superglued together (as seen on Crimson Guitar videos).
The pickup cavities are now bigger than the very thin pickup surrounds I had planned to use, so instead I'll make my own pickup rings from wood - and pretend that was what I had planned to do all along.
I then spent a few hours sanding to get the shape and finish right, before covering the body in brown stained pore filler.
Another two hours of sanding and the body looked more or less exactly the same as it had done before I applied the grain filler. I hope that when I put on the Tru Oil the coloured grain will be more obvious.
Now the bad news. If you are squeamish, look away now. I tried to be clever and save some time by profiling the side of the neck with the router, using the finderboard as a template. It didn't work out as planned. Another set of materials for the neck is now on order.
I suggest you take a step back, practice on some scrap, and figure out how to hold things better before continuing.
Is it fair to say every mistake so far is because a template has slipped? Are you using the correct bearing topped router bits? is the router gripping them adequately?
Instagram
So FOLLOW it!
If there is a "clever way of saving time", Mark would have put it in the course already. He's made enough guitars over enough years to have found the shortcuts.
This time you've just wasted some wood and some time. But even trying that approach suggests that you've not really considered the capabilities and limits of the tools you're using - the router in this case. The router is a reasonably dangerous piece of kit, in that it can do a lot of damage very quickly. This time the damage is only to the wood, but if you misuse it again the consequences could be more serious. And painful.
Be careful with the tools!!
https://www.amazon.co.uk/dp/B00OOULCWM/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=27WH20KJ6EISH&coliid=I1RTI0ZU8AJ3J7
Respect for posting the picture, I wouldn't have!
