Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Instagram
Find a way to clamp and apply the pressure on the actual board whilst gluing, not the frets!
EDIT
Sorry miss read the question, so for get the above. I have fretted finger boards be for gluing them to the neck, but only when replacing the fingerboard on an acoustic guitar. But I don't recommend as other people said quite difficult to get the fingerboard on in the right place and flat. I also used to do it when I first started making Les Pauls as per the Gibson way, very quickly decided was not way to do it.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
So if I did it again I think I'd stick it to the neck before fretting (obviously cut the slots first though).
do you fret the fretboard before attaching to the neck though?
Instagram
I haven't had a problem so far, make sure your fret slots aren't too tight
I also press frets in which helps imo.
(formerly customkits)
it allows for even and on spec fret heights and the avoidance of common issues with board curvature.
This has to be done as the final stage before fretting and can't be achieved if you pre-fret the board.
I can't think of any design feature that would prevent doing it this way.
Seek perfection not convenience.
