SOLD: RCF ART 705-AS Active PA Subwoofer - Made in Italy
Very powerful active subwoofer in excellent condition with a built in switchable crossover. Supplied with a powercon mains cable and original manual. This is the Mk 1 version which was made in Italy, so a high quality loudspeaker.
I've been running the stereo outputs from my mixer into the crossover in the sub, then out to my tops, but it doesn't get enough use to justify keeping.
ART 705-AS is an extremely compact high output active subwoofer system that delivers tight, fast controlled bass response at very high efficiency levels.
The High Current 800 W Class H amplifier provides the best performance alongside an increased dynamic range.
The Baltic Birch plywood enclosure is painted with black, heavy duty, textured epoxy.
The front is protected from a strong powder coated, metal grille.
The RCF Precision “Inside/Outside” voice coils assure long term reliability and vastly reduced power compression.
800 Watt amplification
130 dB max spl
15" woofer, high power 3" voice coil
Xover selector, phase switch and high pass outputs
40 Hz response down
Collection from Near Norwich or I may be able to deliver in East Anglia if you're not too far away. £350
