Digitech GSP1101 GASsage....BARGAIN.
siraxemansiraxeman Frets: 1935
Well I think so anyway. £90 posted....I thought even with its fault its worth it. The fault..? Well, the amp volume control has snapped off, i'll try and fix it but if not its no biggie can still turn it with a screwdriver, and really its not a control I'd probably use that much live anyway...you can edit all the levels inside anyway with the main value dial thingy. If its FX are as good as my G Major I might flog that and be a few squids up on the deal. Either way its a new toy that has some good sound in it for only £90 so looking forward to having a play around with it.
  • dindudedindude Frets: 8540
    I really lied my GSP1101 when I had it, can get se great sounds out of it.
    Yep! That's a good price!
  • longshinslongshins Frets: 247
    make sure to get the mustbebeta update for it, it means you can load impulse responses into it.
    ^^apparently tis already in there! :-)
