My favourite pedal.
You can do feedback or delay time, the only problem is it's an internal switch so once the delay is on my pedalboard I can't change between them. I use the Moog ep3 which comes with the TRS cable you need to connect it.
My pedalboard an iteration ago but the MF Delay and EP3 expression pedal haven't gone. My delay is all black, the one in your picture is black and silver because they changed the look of the range to that although, as far as I know, everything else stayed the same.
