Small amp heads with midi channel changing??
bloodandtearsbloodandtears Frets: 1689
Or should I buy a HT5H and an RJM amp switch gizmo??
Following on from some recent thread I am toying with the idea of messing about with my Line 6 HD500X in 4CM...
My trading feedback
  • professorbenprofessorben Frets: 5105
    Sack off the RJM and get a Nux Pms 2
    £25 and solid.
  • octatonicoctatonic Frets: 33851
    It can be a bit of a rabbit hole to go down due to latency.
    Some amps drop out momentarily- it might only be 20ms or so but you notice it and it sucks when it does.
    That's pretty bad, most Midi instruments I've come across have a maximum latency of ~8 ms
  • bloodandtearsbloodandtears Frets: 1689
    £25 and solid.
    @professorben
    have a wis right there..
    My trading feedback
    @octatonic
    is that specific with the NUX or with this premise in general?? the voodoo labs one looks similar but 5 times the price..
    I'm guessing I need to make sure the NUX switching capability would be compatible with the HT5H or whatever..
    My trading feedback
    In general.
  • John_AJohn_A Frets: 3775
    @octatonic
    The NUX has no noticeable latency - you can also configure the polarity and set to latched/unlatched so it will work with anything - great little units.  The outs are stereo(TRS) though so you may have to buy some insert leads
    @octatonic
    Yep, it's a fast little unit, I've used it tonseitch my Engl and Mesa, both needed stereo jacks so was plug and play, but an insert cable would do the trick, they can be had for a couple of quid, cheap and cheerful as it's not carrying any audio.
    @bloodandtears ;
    when you say small head? Do you mean power or size?
    The Evh 5150 iii 50w has midi switching.
    If it had power scaling in the Head version I'd be half tempted except the BIG price lol
    My trading feedback
    Power amp drive is naff mate.
    Preamp all the way  ;)
    @John_A ; @professorben  ; did either of you Nux users implement it with a momentary switching amp?? I read there are issues with such... and it's good with latching only...
    THe HT5 being momentary of course.. typical...
    My trading feedback
    There are two settings for the momentary - short and long (they really have thought of everything) used it with an AMT stonehead that apparently has issues with some external switchers and on the 'long' setting it worked great
    Hmmm not sure tbh, whatever the Engl and Mesa are.
  • JetfireJetfire Frets: 1696
    Im kinda always saying hughes and kettner
    @bloodandtears  hey just found my Nux Switcher.
    Its yours if you want it dude.
    Just pm me your addy.
    @professorben ; pm'd you
    My trading feedback
  • FTR..  a NUX PMS2 works with a HT5R head..
    My trading feedback
