Active to passive pickups advice on Pots.
the_great_huszarthe_great_huszar Frets: 1
edited August 2017 in Making & Modding
I have an Epiphone Les Paul Prophecy plus currently fitted with active EMGs which I plan replace with Seymour Duncan AP2 to tame it down a bit.
Now my question is, do I really need to replace the pots? Or can I leave them in for now and replace later?!
Thanks in advance
  • fretmeisterfretmeister Frets: 24544
    You REALLY need to change the pots at the same time.
    The values are massively different.
  • ICBMICBM Frets: 72536
    If you don't replace the pots, the passive pickups will sound like you're playing underwater.
  • Thanks for the replies, I had a feeling that was going to be the case, but I wanted to double check before soldering in the new pickups to find I need pots.
    I'm thinking 500k CTS liner for both vol/tone and 0.022uf caps. Reading reviews I will have to open out the holes on the Epiphone as they are smaller than Gibson Les Paul's, makes me a little nervous drilling holes on finished surface!
    You will need Log pots for the tones at least or they won't work properly - they will have all the sweep between 0 and 2 on the knob. Linear will work for volume if you don't want a fast drop-off from 10 down to 8.
    Don't open out the holes with a drill, use a taper reamer. (Carefully, from both sides, until you can just get the pot through.)
  • normula1normula1 Frets: 640
    You can now get CTS metric pots which shouldn't require the holes enlarging
    Interesting, thanks, I'll get 2 of each then.
    We must only be talking fraction of a millimetre between the metric and imperial. Great advice thank you.
    I shall definitely look for these first, if unsuccessful I'll get the the imperial size, many thanks.
    No, it's 8mm vs 3/8" (9.5mm) - a real difference in size, rather than a metric/imperial equivalent issue. You definitely can't get US-size pots through far-east-size holes without substantial wood removal.
    If you can get CTS in 8mm now and don't have a reamer, I would definitely look for those.
  • AlegreeAlegree Frets: 665
    Side note: if you're happy going without pots until you replace them, you could just bypass them completely.
    Whoa that is a huge difference lol!
    I do have a dremel type tool with a wide range of attachments.
    Quick browse on the net shows only a couple of places that do the metric one in the U.K.
    I've near done that already with my Maverick, only have one pickup wired in, a Seymour Duncan JB in the bridge, via the vol pot. Everything else is just for show. Really made a huge difference with it.
  • normula1 said:
    Yes I've seen those ones, first one that comes up in the google search. Thank you.
  • Right, the pots have arrived, ended up getting them from Axesrus, but they have put all 4 in one bag with no label. So which one is which?!? Numbers on the bottom are as follows..
    A500 1614
    B500 1523
    Also arrived, new wiring cable, pair of 0.022uf orange drop caps. Just waiting for some copper tape to arrive, may as well shield it at the same time.
    A = Log
    B = Lin
  • normula1 said:
    A = Log
    B = Lin
    Thank you!
    A500 1614
    B500 1523
    Shielding… ah. Does it have a bridge/tailpiece ground wire? Quite a lot of guitars with EMGs don't, because they don't need it - but ones with passive pickups do. If you're lucky, there will be an unconnected wire sticking out of the woodwork on the side of the control cavity nearest the bridge. If there isn't, things get a bit tricky…
    Sorry, I forgot that before.
    A500 1614
    B500 1523
    Just checked, There is a single black wire, coming out of its own hole towards the bridge. It is soldered to a tone pot.
    All the other wires run down more of a slot, obviously towards the pickups.
    Great! It's actually unusual that it's grounded, on a guitar with EMGs… but the important thing is that it's there.
    So I won't be having to talk you through how to pull the tailpiece bushing out of the guitar using a crowbar :).
    Only a crowbar!  =) no screw driver to pry around the bush and ruin the top coat?!? Haha.
    In all seriousness, if it wasn't there I'd have bought a new guitar, even though I can't afford one.
      :o
