I'm so ham fisted
That I managed to snap the head off of one of the bridge plate screws on a tele while tightening it. I would usually drill it out and plug / re-drill if i did this on anything else, but want to check if anyone has used or can recomend another method?
It won't be straightforward any which way  :s
  • Winny_PoohWinny_Pooh Frets: 7790
    edited November 2017
    Screw extractor kits. Or for diy buy hollow brass tubing just wider than the screw. Notch in some teeth at the front and pop it into your drill.
  • WezVWezV Frets: 16748
    I am sure we have all done it at some point.
    If it’s slightly above the wood you may get lucky with some good grips pliers or snips... get cutters are very good for getting a grip on a protruding screw before slowly turning out... sometimes a bit of heat from a soldering iron helps.
    If if it’s not protruding, the brass tube method works well
    Once its out plugging and re- drilling is the way forward.
  • ICBMICBM Frets: 72531
    Heating it with a soldering iron works very well - make sure you get it good and hot, up to the point the wood starts to char if it won't come free before that - at least with it being covered by the bridgeplate a bit of a burn mark won't show. Even if it's flush with the surface, you should be able to get some sharp pliers or cutters onto it, it shouldn't matter if it chews up the wood a bit.
  • impmannimpmann Frets: 12669
    Thats what I'd do.
    I did see a brilliant video that I can't find right now, where the tech used a Dremel (or similar) to cut a slot in the top of the broken off screw, he then heated it with a soldering iron and then simply unscrewed it using a flatblade screwdriver.
  • MrBumpMrBump Frets: 1244
    Wow!  I never knew you could get a screw extraction kit!!!
    Mark de Manbey
    Trading feedback:  http://www.thefretboard.co.uk/discussion/72424/
  • martmart Frets: 5205
    impmann said:.
    So do you unscrew it while the screw is still hot, or wait for it to cool down first?
    I’ve never had any success with this method so I’m wondering if I’m doing something wrong.
    I get the screw hot to the point where its starting to smoke and then I've been able to wind it out...
  • Screw extractor kits.
    i second this. they are quite cheap and work good. if you like your guitar maybe resist going crazy improv with heat etc that could bubble your finish if you can easily avoid it.
    i am the hired assassin... the specialist. i introduce myself to you... i'm a sadist.
  • TADodgerTADodger Frets: 211
    Thanks all - First I need to look at how far in it broke as I hung it back up in disgust last night!
    i have screw extractors but generally not impressed. I quite like the idea of cutting a slot with a Dremel and unscrewing it.
  • RolandRoland Frets: 8745
    TADodger said:
    ... I hung it back up in disgust last night!
    Always a good policy. If something goes wrong in the workshop then walk away and have a cup of tea while you think about it.
