The circuit in the Festival isn't the same as in the ZIM, so it won't sound the same, but it'll be good.
Big TGP thread with input from Dave Fox himself:
https://www.thegearpage.net/board/index.php?threads/foxrox-festival.1463275/
I imagine the live application of the voice control is great for cutting through the mix as the night wears on and the pub fills up.
I have the foxrox paradox and one its many interesting applications is the comb filter of the 'manual' knob. I wonder if the body control on the aim uses the same principle. and yes, it does sound like an out of phase jimmy page.
R.
Eqd Speaker Cranker clone
I doubt he would get a ts9 so wrong that it was miles away from any other ts type circuit so all that tells me is @lukedlb doesn’t like tubescreamers.
as for preferring fuzz faces...I don’t think there’s anyone on the planet that knows what makes a good fuzz face better than foxrox with his cv?!
There are plenty of ways to set the voice control on the ZIM that introduce fairly extreme EQ cut or boost that do sound quite 80s, but they can be dialled out.
The fuzz ZIMCards are either Big Muff or Si fuzzface based- apparently there's an overdrive built in to the fuzzface to better integrate with clean amps, but otherwise it's a Dave Fox fuzzface, which ought to mean it's good. If a fuzzface is what you want, anyway.
It's pretty much all subjective though, so if *your* ears say it's no good, it's no good.
I have a paradox ztf and rate the Foxrox gear highly and tested it through vintage Marshall superleads.
My hope is the festival is more open and the body pot will have more application. I often use the paradox as a matrix filter by using the manual pot to set the body of the guitar.
Last thing: the fuzz is definitely not a ff circuit.
Technically, you could probably make that argument. But from what Foxrox say about it, it's definitely supposed to sound like one.
http://www.foxroxelectronics.com/FFZIMcard.html
R.
