Anyone got a Gigrig Virtual Battery?
NickBotfieldNickBotfield Frets: 143
Has anyone got a Virtual Battery?  If so, can you use it as part of a common or garden daisy chain or does it need to be plugged into a Gigrig setup?  I've got a very noisy delay pedal that could do with being isolated, see.
  • TimmyOTimmyO Frets: 7509
    You can add it to a daisychain and that pedal will be isolated, BUT note that the VB itself needs current to operate so if you're operating near the limit of your supply it might be an issue
    Red ones are better.
  • ToneControlToneControl Frets: 11947
    I have one running an MXR phase 90, got it from Thorpy in 2011
    It's happily worked for years from a normal isolated output, Burkey
    Doesn't need a gigrig PSU
  • Good information.  Thanks!
