Wudtone/Osmo to finish a neck?
lovestrat74lovestrat74 Frets: 2530
edited January 2018 in Making & Modding
Hi anyone used wudtone to finish a neck before?
I have a bare tele neck that i would like to give an aged/vintage tint. It appears to me to be an easier solution compared to nitro spray.
 PROS? CONS? Any tips welcome.
«13
  • MegiiMegii Frets: 1670
    I used it (actually just the Wudtone clear basecoat stuff left over from finishing the guitar body, no tint) to finish a neck once, and it did come out nicely. Just sanded the neck lightly to 600 grit, and then a few very thin coats, and buffed using a bit of copy paper and elbow grease.
    Although I think if was to do a similar job in the future, I'd probably use Tru Oil instead. But it certainly worked well enough. :)
  • GizmoGizmo Frets: 1078
    Id buy one of these Osmo Sachet/testers in Honey and save yourself £30
    https://www.amazon.co.uk/OSMO-Polyx-Tints-Sachet-Honey/dp/B00TKB2MSI/ref=sr_1_3?ie=UTF8&qid=1513195612&sr=8-3&keywords=osmo+oil
    the 5ml in that would be more than enough for a neck and the Osmo stuff gives a really nice gloss but non sticky feel,ive used it on the past 4-5 builds/rebuilds ive done and i wouldn't use anything else now
    I've got try oil but I need something to tint the neck to give it that vintage look
    Sounds very interesting @Gizmo !
    Id say grab one of the honey and one of the amber and do a test on the heel area that would be hidden in the cavity to see which you like,if it doesn't work for you just rub it down and you've only lost £2.80 ;)
    2 sachets ordered. I'll let you know how it goes  ;)
    This. With or without a tint underneath.
    Feedback
  • I did a neck with the vintage tinted Wudtone kit and it works well, but I still have a load left over which will now surely dry up and finish in the bin. Bearing in mind it's basically Osmo, do as Gizmo says and get a couple of those sachets and you'll be laughing.
  • t1000t1000 Frets: 94
    I got the vintage aged kit from wudtone and was dissapointed with the colouring I was about to order an amber kit from them then read this thread just ordered the Osmo sachet. Thanks Gizmo. Do you need to topcoat the Osmo?
  • RolandRoland Frets: 8750
    Osmo normally dries within 24 hours, and hardens within a days or so.
  • gavin_axecastergavin_axecaster Frets: 526
    First trial with the honey Osmo. I think this is 4 applications - I'm not actually sure it's taking on any more colour with each coat. Raw neck for comparison. (There are 2 bright spotlights shining on the table, so the centre of the neck isn't actually that light)
    It's not bad - wish it was a little darker. Feels great when dry, even without buffing yet.
    That looks great :)
  • aord43aord43 Frets: 287
    How much does one sachet cover?  5ml seems a very small amount.
  • I used a vintage amber, can't remember the exact description. It was way to orange. Sanded it all off and sprayed a light brown from Rothko & frost, which was perfect as that has a bit of amber in it. I'd did a thread on a blackguard build I did with pictures if you're interested.
    Thanks for the report back @gavin_axecaster
    The honey defo has a slight tint,this is the osmo top oil on my back to raw maple HM strat neck x2 coats
    I find the Osmo Top oil to be somewhere between polyX and normal tru oil finish,
    @aord43 5 ml of oil should give you about x3 light coats on a standard neck,Id suggest wrapping your application pad/cloth in clingfilm between coats so it wont cure & you don't waste any repriming your pad,sure its not economical to buy these sample sachet's if you have a lot to do but for a single neck/test its better than paying £20-30 and having a few 100ml's left sitting in a bottle.
  • You can add a little oil based varnish which will darken it a bit and give a slightly glossier finish if it gloss varnish if you are working with satchels probably not but mixing up 10-15% seemed to work well still goes on with applicator
  • Still waiting for my sachets but once I have finished the neck I'll let you all know how it went
  • FatPeteFatPete Frets: 683
    Does the Osmo stuff have a similar odour/'amount' of odour to Wudtone?
    Trading feedback: Trading feedback
    Looks good, almost has a roasted look about it!
  • lovestrat74lovestrat74 Frets: 2530
    edited January 2018
    Finally got round to this and I am really pleased with the finish - although a bit hard to capture on phone camera.  I used honey first then applied the amber as the honey wasn't quite dark enough.  Thanks for the tip @Gizmo !!
