Broken switch?
TeetonetalTeetonetal Frets: 7817
Got a fender ja90 Tele. Not used it for a few weeks. Tonight no bridge pickup, so middle and bridge positions don't work.
Lp wiring on this. Broken switch?
  • richardhomerrichardhomer Frets: 24851
    edited January 2018
    IIRC, they have a Les Paul type toggle?
    These ‘can’ get stuck if left in one position for a while. Have you tried switching back and forth several times?
    I leave my 335 in the centre position while it’s in its case, to avoid this happening.
  • TeetonetalTeetonetal Frets: 7817
    Yes.. it's am lp. Left in neck position.
    Does getting stuck stop all sound when switched?
    Can do - it’s a common problem with this type of switch.
  • ICBMICBM Frets: 72695
    edited January 2018
    It's not a switch problem - if it was, the neck pickup would still work in the middle position.
    If there's silence in the middle position as well as the bridge, the fault is a short in the bridge pickup wiring. (It could still be a short *at* the switch in the bridge pickup connection though.)
    When it's in the middle position, does turning down the bridge volume control bring the neck pickup back in?
    Nope. Completely dead in middle and bridge.. Checked the loom and no obvious break' or cracked solder.
    edited January 2018
    There won't be - it's a short, not a broken connection. Look for something (bare metal) touching something it shouldn't be.
    If it's still silent when the volume control is down, it's at least not the pickup - it's either at the volume control, the switch or the cable in between the two.
    (I should have said check in the middle position *as* you turn the volume down, not with it right down, if that makes any difference!)
    @ICBM found it. On the bridge vplume pot there is a small wire connecting the bottom lug to the centre of the pot. Pushing it to a different position and we have noise again.
    Not the neatest loom I've ever seen... lot of extra cable in there.
    I have a feeling I should replace that wire. Wiggling it causes a cracke and loss of sound in a random way.
