What size and where to get a hex nut for a Jazzmaster pickup toggle switch?
Anyone know what size these are and where to get a hexagonal nut for a Jazzmaster pickup toggle switch? Is this the sort of thing you'd find in B&Q?
  • It’s 13mm, I can tell you that much (just checked mine.) I’d have thought B&Q was a pretty safe bet, yeah
  • Ignore that, you said pickup not jack input. It seems to be a 15mm. Don’t have a 15 spanner to check, but the 14mm doesn’t quite fit.
  • m_cm_c Frets: 1247
    Nuts are measured by thread size, not spanner size.
    Switches are likely to use a fine thread, and very thin nuts. Given B&Q don't stock either fine threads, or thing nuts, I'd very much doubt they'd have something that would fit.
    Easiest option is normally to pinch a nut of another switch, as it's quite often cheaper than trying to source just a suitable nut.
  • PhiltrePhiltre Frets: 4175
    I've done a search for "Jazzmaster toggle switch" and can get replacement switches for a hefty price, but all I need is the nut.
  • ICBMICBM Frets: 72563
    I’ll send you one, I have loads.
    USA or Japanese Jazzmaster? The switch threads are different.
    @ICBM - that's very kind of you. USA model. Can I PM you?
    Of course :).
