how reliable are the Marshall dsl, tsl, jvm etc amps
riffpowersriffpowers Frets: 344
shopping round for a cheap(we) Marshall and i wonder how reliable the more modern marshals are ??
I often see dsl , tsl and jvm amps for sale locally and am tempted to pick one up .
Worth a punt ? Any to avoid ??
  • The footswitches on TSLs are known to break. I understand other things are too. I've had both (rented) TSLs and DSLs let me down on gigs, which fits with rumours I've heard about their unreliability, but I don't know how representative my experience was.
    My YouTube channel, Half Speed Solos: classic guitar solos demonstrated at half speed with scrolling tab and no waffle.
  • ICBMICBM Frets: 72497
    Your experience is not unusual.
    UK-made DSLs and TSLs have various design and manufacturing flaws which tend to make them prone to failing... although as with anything like this, some people also say they’ve used them for years with no problems.
    Personally I wouldn’t buy one, with the possible exception of the DSL401 combo, and even that needs work to make it reliable.
    JVMs and the current Vietnamese-made DSLs seem pretty good.
  • DJH83004DJH83004 Frets: 196
    I honestly don't know why (Other than quality control issues), but some DSLs / TSLs work totally reliably, with lots of abuse - in rehearsal rooms for example, yet others are plagued with bias drift and other known issues, so there are musicians who love them to bits because they have never been let down and others that hate them with a passion, I have seen a mix of both, but the rehearsal room / studio guys do like their flexibility.
  • andyozandyoz Frets: 718
    edited January 2018
    But a JVM Joe Satch model...best second hand bargain around if you want a great gigging amp and can handle the bulk.
    I never had any problems with my old DSL100’s or the jcm900. I know guys who have had problems with JVMs and VintMods.
    The one you need is a JCM900 SL-X
    harder to find but if you want a switchable boost and the classic modern Marshall tone, it’s unbeatable
  • ecc83ecc83 Frets: 1638
    Stand by, sentimental ***t coming in!!...
    Back when I was an R&TV tech the major manufactures, Sony, Hitachi, Ferguson had excellent service backup systems. You could phone them if you had a particularly sticky fault (if you were a dealer) and get top advice.
    One mnfctr, Rank Bush Murphy was especially good. Not only did they have a team of 'Technical Liason Officers' very experienced guys from production but they even produced a quarterly A5 booklet with service tips and a list of all currently reported faults across the product range. There was an annual index and they even provided stout outer files to keep then all in!
    These days a 'decent' firm COULD provide a data base of faults. Anyone know of one?
    Dave.
    These are great amps, and the dual master volumes give the switchable solo level - without changing anything else.
    The earlier High Gain Master Volume models are OK too (and available as combos if you want one, which the SL-Xs never were), but the 'sensitivity' stage which uses the fourth preamp valve in the SL-X is done with a diode clipping circuit - some people don't like this, although if you don't have the sensitivity up too far it doesn't do much.
  • rawk100rawk100 Frets: 1757
    I've owned jcm900 duel reverbs, jcm2000 DSL, jcm800 and presently have an SLX.The only amp that let me down was a duel reverb.
    The SLX is a great amp and has more gain than an 800 and is more "modern" sounding.
  • Modulus_AmpsModulus_Amps Frets: 2583
    I have a reliable DSL 50w head from 2004 ish, had to replace the reverb tank once and did a fix on the power valve socket board a few years ago. I have often thought of selling it as I have so many amps, but it is still here.
    They have a bad rep but they also made truck loads of them, so there is bound to be a perception of higher failure rate.... which goes with the inherent design flaws.
  • impmannimpmann Frets: 12668
    Put simply... "not very".
    edited January 2018
    True up to a point, but I'm certain the failure rate is actually higher even in proportion to the numbers made. There are other very common amps - eg Fender Hotrods - that we see more than most other amps as well, but still less than the DSL/TSLs, and the types of failures are almost always much less serious and expensive to fix as well. (That may not quite apply to the Blues Junior though...)
    I recently acquired a dead TSL100 combo with several faults for the parts value, and although I could very likely have fixed it by replacing the main PCB, I didn't want to commit that much more money to something I could not sell with a straight face or absolutely guarantee to the buyer. Within six months I had needed both transformers for repairs on other ones, and that's not that unusual. Total number of transformers I've replaced in Fender Hotrods since the series started... 1.
  • zepp76zepp76 Frets: 2534
    Get a used DSL40C, cheap, reliable and with a speaker change a very good sounding amp.
    Tomorrow will be a good day.
  • longjawlongjaw Frets: 423
    This.
  • I have a DSl401c and never had a problem with it. It’s awesome.
  • CollingsCollings Frets: 411
    I think the TSL had some changes to the PCB to try to remove the cause for the bias drift problem along with other design problems  so the amps with the later revision pcb should be more reliable.
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    edited January 2018
    I've got a mid-90's JCM900 Hi Gain Dual Reverb 1x12, bought when it was nearly 10 years old. I love it, it's been gigged and hasn't let me down.
    Only bad thing is the footswitch cable works intermittedtly, but it must've been up/down stairs at home, in/out the car and to a gig or rehearsal at least 100 times.  Also had the valves replaced and a couple of noisy pots when serviced by Marshall (twice) in the 15 years I've had it.  Not because it wasn't working... more a safety net before a run of gigs.
  • VoxmanVoxman Frets: 4726
    I'm curious, what's a dsl401c and how does it differ to the dsl401?
  • GrunfeldGrunfeld Frets: 4040
    Weekly gigs with a regular JVM 410h for 6 or 7 years without problem.  Valves needed changing of course.
  • ricorico Frets: 1220
    DSL40C is the successor to the DSL401.
  • randellarandella Frets: 4218
    I have the Hi Gain Master Volume version which is, as far as I can tell, indestructible. It just feels brick-solid.
    Far too loud though.
