Major scale chords
the chords in a major key of G are Am,Bm,C,D7 ,Em, F#something
why does F work ? for instance G,F and C in the key of G is great for blues and major scale soloing.
Also G, BFlat and C
whats the relationship between these chords? I am a theory Neanderthal
  • Cos they're borrowed from a parallel minor scale meaning you can use F, Bb and C chords that also contain notes in the minor pentatonic scale too (flat 3rd, 4th and flat 7th).
  • sm55onlsm55onl Frets: 28
    edited January 2018
    G Major scale
    http://www.guitar-chords.org.uk/guitarscales/g-major-scale.html
    • G Major Scale Notes: G A B C D E F#
    • Scale Formula: 1 2 3 4 5 6 7
    • Scale Intervals: W W H W W W H
    G Major chord progression
    http://www.guitar-chords.org.uk/chords-key-g.html
    G (natural) minor scale
    http://www.guitar-chords.org.uk/guitarscales/g-natural-minor-scale.html
    • G Natural Minor Scale Notes: G, A, Bb, C, D, Eb, F
    • Scale Formula: 1 2 b3 4 5 b6 b7
    • Scale Intervals: W H W W H W W
    G minor pentatonic scale
    http://www.guitar-chords.org.uk/guitarscales/g-minorpentatonic.html
    • G Minor Pentatonic Notes: G Bb C D F
    • Minor Pentatonic Scale Formula: 1 b3 4 5 b7
    • Scale Intervals: W+H, W, W, W+H, W
    [Edit: added]
    G Blues scale
    http://www.guitar-chords.org.uk/guitarscales/g-bluesscale.html
    • G Blues Scale Notes: G Bb C Db D F
    • Blues Scale Formula: 1 b3 4 b5 5 b7
    • Scale Intervals: W+H, W, H, H, W+H, W
    Make the Blues scale
    https://www.guitarlessons.com/guitar-lessons/blues-guitar-quick-start-series/how-the-blues-scale-is-made
    Also, (jazz) chord construction
    http://www.jazzguitar.be/blog/jazz-guitar-chord-theory/
    [Edit 2]
    Blues Scale
    http://www.howmusicworks.org/406/Scales-and-Melody/Blues-Scale
  • Steve-OSteve-O Frets: 37
    edited January 2018
    You are asking why the note F works well in a G major scale instead of the F# right?
    I think I understand your confusion as a theory novice myself.
    My take is the F note is the seventh of the scale (the major seventh)
    With F
    # you get the dominant seventh.
    so G,B,D,F     Major seventh
         G,B,D, F#  Dominant seventh
    The dominant seventh is a kind of neutral note and can be played over both major and minor chords. So you can play F over G maj or G min and it won't sound like a bum note.
  • ArchtopDaveArchtopDave Frets: 1368
    edited January 2018
    With F# you get the dominant seventh.
    You have got it the wrong way round. F Sharp is the Major Seventh, so this note gives you G Major 7. F is the flattened 7th, giving you a Dominant Chord. The flat 7, I.e. F in this case, works in Blues, because a basic Blues Progression is a series of Dominent Chords.
    edited January 2018
    The dominant 7th is, to some extent, the sound of blues and jazz - so heard a lot in popular western music for the last 80 years. So we probably find it easier on our ears than the major 7th ( any one time traveling from 200 years ago might find it less pleasant). It is still slightly dissonant which is what gives it that restless quality - so if you hear a dominant 7th chord you then want to hear it resolved. In that sense it actually doesn't work - it's a kind of not working that we like though.
    Edit : in this case the F is the dominant 7th as Dave points out.
    edited January 2018
    The F# something is the half-diminished chord aka F#-7-5 or F#m7(b5).
    Don't confuse the use of 'Dominant'. The 'Dominant' note in the Gmaj scale is D. When you harmonise the D you get D dominant 7 (R 3 5 b7, D F# A C). That formula is known as the Dominant 7th form of a chord. The leading note of the G scale (F#) is the 7th degree of the scale, F natural would be the flattened 7th or minor seventh as an interval calculated from the root G.
