Will a buffer revive a tone sucking pedal?
I have a Modtone Chrous which has extreme tone suck when not on. I'd like to keep it, as it sounds good when engaged, but wanted to know the best way (if possible) to remove the tone suck. Will adding a buffer bring the tone back to life, or will a bypass pedal be better?
Cheers all ;-)
  • You would need a bypass for it to take it out of the chain when not engaged.
  • ICBMICBM Frets: 72949
    A buffer in front - any buffered pedal like a Boss - will work.
  • impmannimpmann Frets: 12704
    You can’t put back what has been taken away.
    Stick it in a loop.
    Stick it in a loop.
    No, but you can stop the taking away.
    A buffer afterwards would do no good, but one before will.
    ICBM said:
    Stick it in a loop.
    It depends on what and how it’s being taken.
    If it’s True Tone suck, a buffer *may* help but if some of the frequency response just isn’t passing through, it won’t change things, in my experience. I don’t know the pedal involved so can’t comment but I’ve found that the only way with some pedals is switching them in and out of a loop (example original release Ibanez Sonic Distortion).
  • slackerslacker Frets: 2269
    Imho boss pedals suck tone. I sold all mine and got my treble back. Bypass loops are cheap and effective.
    However you go down the rabbithole of true bypass mixed with long cables.so you might need a buffer, but subjective opinion alert not a boss one.
    With any problem solving, you need to change one thing at a time, change it back etc. Try to borrow a loop pedal, shudder a boss pedal and see what works without buying anything. Oh short decent cables are your friend patch included.
    1reaction image LOL 1reaction image Wow! 1reaction image Wisdom
  • UnclePsychosisUnclePsychosis Frets: 12999
    Boss pedals don't suck tone. The boss buffer sucks a tiny bit of volume which the ear perceives as tone. Turn the amp up a smidge and the "tone" returns.
    Boss buffers do not suck tone. What they do is very slightly reduce level - the buffer is not quite unity gain. You probably won’t notice with just one, but run a few in series and you will - and you will hear it as an apparent loss of tone and not volume, due to a quirk of psycho-acoustics.
    The reason I would use a buffered pedal and not a loop switcher is because you then get another useful effect! Instead of an otherwise useless extra box...
    Beat you to it @icbm, you're slacking :-P
    It took him a few extra seconds to bang his fist on the desk shouting “not this again!”
    lol
    You just wrote half as much :).
    That is true. The vast majority will be fixed with a buffer in front though.
    Fair enough gents but if the op buys a boss pedal and can't live with the tone,volume, mojo suck he's out of pocket.
    Borrowing one - or buying one of the millions of second hand ones, so you can sell it on at no loss if you don’t like it - would answer the question though.
    Buying a loop switcher if it isn’t really necessary also puts you out of pocket :).
    There you go
  • The old hornet's nest has been stirred up!
    Thanks for all the replies chaps :-)
    I have a Boss pedal, so I'll give that a crack later on today and report back, in the hope that it doesn't start too much grief on here ;-)
  • Well the verdict is that this pedal just plain sucks! That's a shame as the chorus sound is good. The Boss pedal did nothing to revive the tone of this baby (known for being a tone sucker, but not by me when I bought it!). I imagine that it's just plain bad circuitry, as there is a version II that exists i believe.
    Cheers for all the input as always. Now, back to my Chorus search... :-)
  • lasermonkeylasermonkey Frets: 1940
    My understanding is that a few, including the CE-2/3 do, as the pre/de-emphasis circuit is always switched in. That said, I just adjust the eq on my amp accordingly and rarely turn my CE-3 off anyway!
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • FrizerFrizer Frets: 45
    Lehle Sunday Driver is another boost/buffer option.
  • skunkwerxskunkwerx Frets: 6886
    Buy a bright onion mini looper (its a true bypass loop pedal which will take the chorus effect out of your chain entirely when not on, so you can effectively leave the chorus on all the time, only needing to stomp on the looper to engage it).
    Not to be confused with audio loopers like the boss loop stations etc.
    Or for a little more (£10 or so) buy a used sd or ds 1 or something.
  • FretwiredFretwired Frets: 24602
    edited March 2018
    ICBM said:
    Stick it in a loop.
    This.
    I have a TC Bonafide which works well. Vernon Reid uses one .. check out his pedal board from Hell.
    https://www.tcelectronic.com/Categories/Tcelectronic/Guitar/Stompboxes/BONAFIDE-BUFFER/p/P0CLK
