Tone Control Wiring Order
What is the difference in wiring the tone control like:
volume pot -> capacitor -> middle lug of tone pot then the outer lug of the tone pot connected to earth
Volume pot -> outside lug of tone pot then the inside lug of tone pot -> capacitor ->
  • ICBMICBM Frets: 72559
    None. The order of the components, or which order the terminals are used on the tone control, does not matter.
    It's purely convenience, usually determined by the physical size of the cap.
    Thanks for the quick reply!
  • FunkfingersFunkfingers Frets: 14554
    thegummy said:
    What is the difference ...
    Using the capacitor as the physical link between the two pots would have saved Leo Fender the cost of a couple of inches of insulated conductor wire in every Telecaster.
    It is an odd choice given how much of a penny-pincher he was notorious for being!
    Even more so, they could have used the two inches of wire saved (although actually not the same piece, it's the wrong colour) to make the ground wire from the jack reach the volume pot as it should be instead of the tone pot, at no net cost.
