Sold - Vox AC4TV8 - £110
CountryDaveCountryDave Frets: 859
edited May 2018 in Amps £
Great little amp that sounds just like it should. Superb condition. Hardly been used.
All Tube VOX tone to go
Way back in 1961, VOX rolled out the first AC4 amplifier. Nearly fifty years later, VOX is pleased to announce the AC4TV8 – the compact, all-tube practice amp. Not simply a re-issue, AC4TV8 is an up-to-date rethinking of the tube circuit that matches today's needs.
Main Features
  • Compact all-tube amp provides real vacuum tube amp sound
    enjoyment
  • Output Power Attenuator provides full gain distortion – even
    at low listening levels
  • Robust sounding 8-inch speaker developed in cooperation
    with the Celestion, the trusted name in speakers
  • Distinctive "TV front" design based on a motif from the
    VOX AC15 amplifier from the 1950s
Bringing the AC4TV up to date
The VOX AC4 appeared in 1961 as a 4-watt all-tube amp, and in spite of its compact body, its true VOX tone earned it a favorable reputation. The AC4TV8 uses the classic combination of a 12AX7 tube in the modified preamp and an EL84 tube in the power amp. The power amp is driven with a Class A circuit to deliver a wide variety of tones ranging from that clean British sound to the distinctive VOX overdrive that everyone loves.
Three level power attenuation
In the past, the only way to achieve meaningful distortion from an amp with a single volume control was to raise the volume. The AC4TV8 provides three levels of power attenuation; 4W, 1W, and 1/10 W. Even at the minimum setting of 1/10 W, the AC4TV8 can provide that great tube distortion. This means that you can enjoy your favorite tone even when playing or recording in your own room or late at night.
Speaker developed in cooperation with the Celestion corporation
The rich-sounding 8-inch speaker was developed in cooperation with the Celestion Corporation. A 16-ohm speaker output jack is also provided, so you can connect the AC4TV8 to a large speaker cabinet such as the VOX V412BN to perform using an even more powerful sound.
Retro "TV Front" styling
The AC4TV8 features the "TV front" vintage look, as used on the first AC15. This amp, which appeared in 1958 is one of the traditional VOX amp designs, and was most recently used on the AC15H1TV from the 2007 Heritage Collection.  It's a stylized retro look that's also an ideal complement to today's modern decor.
VOX AC4TV8 Specifications
Controls: TONE, VOLUME, OP LEVEL (4W, 1W, 1/10 W)
Input/output jacks: INPUT, External Speaker jack
Output: 4W RMS 16-ohm - Speaker: 1x 8 inch 16-ohm Celestion VX8 custom speaker
Valve/tube complement: 1 x 12AX7 (pre) / 1 x EL84 (power)
Dimensions: 11.81"/300mm (W) x 12.68"/322mm (H) x 7.64/194mm" (D) Weight: 15.65 lbs/7.1Kg
£110 - collected from Leyland, Lancs
I'd prefer collection and would be willing to meet within a reasonable distance.
Any questions please ask.
Thanks
