Just use the tip and sleeve for an unbalanced connection.
If you have balanced cable then twist the two that are not the groundwork together and solder to the tip.
You can easily find out which is the tip contact - plug a normal cable into the jack and connect it to an amp. The contact which buzzes when you touch it is the tip. It's usually the shorter one, but some barrel jacks have them the same length.
You can just wire it for tip and sleeve then.
You can't use it for stereo anyway if there's a battery circuit which uses the jack as a switch.
I don't think I need stereo, so I'll have mono and 9v connections, along with a ground?
For a battery switch, the furthest away terminal in the pic is the battery connection. (But check which is the tip using the same method above, just to be sure - the other non-ground terminal is the battery connection.)
https://www.fishman.com/wp-content/uploads/2016/06/Fluence-Classic-HB-Set-Wiring-Diagram.pdf
(as a side note mono 2 prong barrel jacks are produced by Switchcraft).
Most people that fit Fluences put them in Strandy's that were originally EMG loaded, but I'm putting them in a passive Boden.
