Annoying playing issue with my J45 - help appreciated
camfcamf Frets: 1191
edited May 2018 in Acoustics
Hi,
I'm mainly a singer and strummer and I've got a minor issue with a 2002 Gibson J45 that, otherwise, I really like. I seem to be getting an annoying pinging sound as I'm playing. I thought it was something with the nut or bridge but I've had them checked and they seem fine. So I've now come to the conclusion that I'm the problem. Specifically, I think I might be catching the base of my chubby first/pointing finger on the open E string.
Now this is probably down to a terrible technique on my part that I should get some advice on but my first call is to make the guitar take the blame instead.   To be fair, I've never had this issue playing other guitars and looking at the nut, the slot seems quite close to the edge of the fingerboard. Is it worth thinking about having a new nut cut that could bring the strings a little closer together and shift the strings away from the edge a little? Is this workable? Any thoughts or advice? (Other than get some lessons, get new hands or get your fingers to the gym to lose a few pounds? etc.)
I should say that other people playing it don't seem to have this issue - they love it! :/
Thanks for any feedback.
Best,
cam f
    Do you hook your thumb over the low E side?
    If you're the only one that has the problem with the guitar then the chances are the guitar is fine. Have you recently started playing this instrument and noticed the problem, or has the problem recently developed when you didn't have it before on this instrument?
  • camfcamf Frets: 1191
    Yep!  :3
    I do it all wrong. :)
    It just seems to be when I'm playing, so I'm sure the guitar is fine. But I am old and need all my remaining concentration to remember the words and to try to growl in tune, so altering the nut/bridge might be more effective and likely than improving my playing style.
    Not necessarily wrong at all - but I bet if you let your thumb drop round the back a bit (just a bit) meaning you have to arch your fingers a bit more then it would dramatically reduce the zinging.
    I have the opposite problem on bass - I play with finger on the back of the neck, and with my bass playing I like to mute every string that isn't being played so I'm fingers everywhere!
    edited May 2018
    I've had the problem pretty much all the time I've had this guitar. But again, it's really the only time I've had this issue with a guitar. I play all the same songs/chords on my old ES-125 and don't have the issue at all. I did notice that the nut of the ES-125 is a maybe a millimetre or so in from the J45. That's why I'm wondering if a new nut might help.
    edited May 2018
    https://www.dropbox.com/s/mwcalyblochnsox/IMG_3632.JPG?raw=1 ;
    The J-45
    Thansk for taking the time to respond, guys. Much appreciated.
    Might be that your technique is causing the e to buzz because it's closer to the edge of the board than your es-125.. or it could be that the neck is a bit thicker/thinner and means your hand is a different shape, also causing the buzzing.
    I think with a new nut you need to be careful you aren't fixing a symptom rather than the problem - otherwise you could be severely restricted in guitars you can play in the future...
    edited May 2018
  • earwighoneyearwighoney Frets: 3498
    What is the string spacing at the nut as it is and what is the nut width?
    edited May 2018
    The nut is standard 1 3/4" I'm not really sure how I'd measure the spacing.
    Any chance you could take a pic of your hand in a typical chord position on the J-45 when it would buzz?
  • ICBMICBM Frets: 72531
    That's a *big* difference between the 125 and the J-45. I think you may have identified the problem. Personally, I think the top E looks slightly too close to the edge on the J-45.
    Worst case scenario is you have a new nut fitted with the 125 spacing and it doesn't fix it - you can always put the old nut back.
    Who put the low E string on the J-45? :)
    I still think it might be a technique issue if others don't have a problem with the j-45.
    I wonder if the 125 has pushed you to hold your hand in a certain way @camf ?
    I'm only pushing down this line as I had a similar issue 20 years ago which I had to teach myself to correct.. and I've spent a lot of time on hand position and muting with bass.
    Thanks @ICBM. Looks like a new nut might be worth a try. I suspect for some more refined players the string spacing might be fine but it does look quite a bit closer to the edge than the ES-125. I think something with a spacing more like the ES-125 would suit me a lot better although I'm guessing that might also entail a fret dress (although I think that was done not so long ago), a check of the bridge and maybe a general setup too. Are you busy? :)
    Sadly, I think I might have been guilty of the low E offence too.
    You're probably right @Bridgehouse and I might look at getting some general advice and see what I can do but if a new nut helps, then at least I can enjoy the guitar as I'm addressing the playing issue. Up until today, I was considering just selling it, but I really like the guitar and it records really well - so much so, that the engineer in the studio said it was one of the most naturally nice sounding acoustics he'd recorded - one mic straight in front and virtually no EQ. (But that wasn't with me playing it!)
    To be honest, given how you like the 125 so much, I'd be tempted to say get the j-45 done just so it feels the same - regardless of the issue. If you think the nut swap might make you love the j-45 all over again then for the money it's worth it.
    My concern was I didn't want you to mask a potential issue that might rear it's head in a few years when you come to try another new (to you) guitar and it manifests itself again..
    I appreciate the advice @Bridgehouse and I will have a look at it, because I think you make a good point. But I do think it must be the guitar to a degree. I'm a bit rough and ready as a guitarist but I've been playing for 40 years and this is the first time I've ever had this issue. That's one reason it's taken me so long to trying figure what the strange pinging was in the first place. I might still be wrong. But I'll be wrong with a nice new nut and set up. :)
    Don't let me stop you doing the nut - it's the right thing to do! And if it means it plays as well for you as the 125 then you'll be quids in and happy as Larry.
    It's probably a combination of both. Worth looking at the hand position as well just in case.
