Basic acoustic setting on blackstar HT 5R
Hi folks
just wondered if anyone can give any suggestions for amp settings for an acoustic guitar. I’ve got a Taylor Academy 12e acoustic and a blackstar HT5R amp. I like playing stuff such as the Eagles, Creedence Clearwater Revival etc and still very much a “strummer”. Any help much appreciated
Cheers Mike
  • crunchmancrunchman Frets: 11487
    Hi folks
    Cheers Mike
    Is there any reason you need an amp?  At home I'd just play acoustically.   If you are playing out, then there will normally be a PA to plug into.
  • ICBMICBM Frets: 72813
    I think it's unlikely you get a decent acoustic sound out of it at all - it's just too dark, compressed and middy, essentially the exact opposite of an acoustic amp - but if you want to try...
    Use the clean channel and just set the tone control wherever it sounds best, probably full up or nearly so.
    Or - if you can set the gain low enough to not distort - use the lead channel with the gain very low and the volume high, the bass about halfway, middle at zero, treble up full, and ISF to wherever it sounds best.
    Or possibly, if the guitar has enough range on the onboard EQ and volume control, try plugging into the FX return, which will bypass the amp's preamp. (Be careful of feedback, and start with the guitar's volume off.)
  • Thank you for the advice, really helpful
    I usually use the amp with my Strat (I love the sound it makes - not sure my neighbours do) and normally play the acoustic without the amp, but was curious what it would sound like.
  • ecc83ecc83 Frets: 1642
    You could try a more "hi fi" speaker on the Five? Feedback as IC says is likely to be a problem.
    Dave.
  • John_AJohn_A Frets: 3775
    If you have a pre-amp on the guitar, try is straight in to the FX return and EQ with the guitar.  Might work?
  • FunkfingersFunkfingers Frets: 14632
    edited June 2018
    I have a mk1 HT-5 mini stack with an Eminence Legend loudspeaker.
    In answer to the OP question, my recommended settings are:
    Mains switch - off
    Standby switch - off
    Input jack - no connection.
    The Taylor guitar deserves full range sound reinforcement. This probably means P.A. or specialist acoustic instrument amplification - neither of which will be inexpensive.
  • Thanks for the advice - appreciated
