Drive pedal with independent EQ
ZoolooterZoolooter Frets: 887
Apart from the Hampstead Odyssey, are there any other drive pedals that have the option of disengaging the drive. Basically just giving you EQ, so you end up with two pedals in one.
Just missed out on an Odyssey which would have been perfect. Don't want to send more than approx £130 new or used.
  • UnclePsychosisUnclePsychosis Frets: 12956
    EQ pedal plus any drive of your choice seems like too obvious a solution?
  • John_PJohn_P Frets: 2750
    You could try one of the dual drive pedals with the gain turned down.     Or maybe one of the Mesa five pedals that can have the graphic eq switched on one of both channels.
  • ZoolooterZoolooter Frets: 887
    It would be, but I want them in one pedal.
  • ICBMICBM Frets: 72634
    edited July 2018
    Boss FZ-2 Hyper Fuzz/Behringer SF300 Super Fuzz.
    £100-£120 used or £24 new respectively. They sound identical, I have both.
  • hotpickupshotpickups Frets: 1822
    edited July 2018
    I'd get the new team medic from ThorpeFX. Great. Use it with your favourite drive edal
    Nobels ODR-S
  • crunchmancrunchman Frets: 11470
    Fulltone GT500 has a drive side, and a boost/light overdrive side that has bass and treble controls.  If you set the boost for unity with the gain low, it would give you some control over the eq.  I do have one for sale in the classifieds.
    If this is an always on eq ie not in a switched loop solution then try a mini eq ie the typical mooer format size ?  Then overdrive flavour ican be swapped out as tastes change .. pre or posr catered for etc .. maybe hook up with a mini od if footprint is an issue ?
    i use a source audio eq with midi in a programsble looper - eq changing as each drive selected and boost applied as required ..
