Desktop pedalboard alternatives
mistercharliemistercharlie Frets: 333
I find I much prefer to have my pedals on the desk. I play at home 90%+ of the time, and the only pedal I really need to hit with my foot is the looper. I’m also playing into an audio interface and a pair of monitors a lot of the time, instead of fitting up the tube amp in this hot weather.
Currently, though, my desk is a mess. I have the guitar going onto a Mixing Link, then into a Zoom R8, and onto the monitors. In the FX loop of the Mixing Link is a Broadcast, a Joyo American Sound, and a Trio+. The idea is that I can switch the effects in an out. The setup is fantastic, but I want to brig my H9 up to the desk, and an EvenMidi controller.
It’s all starting to get a bit messy.
I’ve also realized that when I do play out, all I really need is a Broadcast, a tuner, and an H9. This means I don’t really need the big pedalboard any more (it’s a PT Junior Classic).
So, what are my options? The studio is also a living room, so it has to be tidy when not in use. Something like this might do the trick, but it’s a U.S import:
I was also thinking about drawers, and about how to use a power supply. Currently the desk setup is using a One Spot and a few wall-warts on an individually-switched power-strip, but I have a Zuma under the pedalboard. Any suggestions?
  • thecolourboxthecolourbox Frets: 9849
    Doesn't somebody use a music stand covered in Velcro on here that might do the trick?
    soundcloud.com/thecolourbox-1
  • I thought about that, but I want to use my existing desk, only to do it without spreading pedals all over the shop.
    get some ply and a few lengths of CSL. You can make whatever you want
    What’s CSL? Google didn’t help.
  • Ah, when I was young, we called that "wood" ;)
  • JAYJOJAYJO Frets: 1527
    I Use amplitube 3 through interface with reaper through monitors. I use a 3 layer intray on my desk. Interface sits on the bottom, leads /spares in middle and headphones on the top. Good to go. Looper pedal is in a old keyboard metal box thingymagig the old monitor used to sit on and is kept under the desk. It has a retractable draw so it just slides out when i need it but i tend to just use amplitube 3 mostly.
  • Paul_CPaul_C Frets: 7826
    "somebody" ?
    httpwwwarrowheadguitarscoukpicsfourstandsjpg
    I like this idea. The three layers seems like a nice idea.
  • @JAYJO What do you use for power?
    edited July 2018
    I just have a power strip with 4 sockets. 2 x monitors 1 x lap top. interface (Steinberg ur22) is usb powered by the laptop. This leaves me one socket. I can plug in looper if needed. (sorry for delay with this ive had to do some work today)
  • GadgetGadget Frets: 897
    If your desk is next to a wall, I've seen people put up a kind of 'pedal notice board' - ie: a bit of wood covered with velcro loop material attached to the wall so you can stick pedals to it and use them within arms length?
    I think, therefore.... I... ummmm........
  • Shark_EyesShark_Eyes Frets: 377
    Check out idea's laptop stands, they're under £5, so one of those with a bit of Velcro could hold 6ish pedals without taking up loads of space
  • Winny_PoohWinny_Pooh Frets: 7788
    I think a slide put desk is good if you keep enough ledroom
    That sounds pretty neat, but it’s not against a wall.
    The slide-out drawer is also an interesting one. Right now I’m leaning toward a three-tier mini shelving unit, to sit on the desk. The middle shelf would either be angled, or slide out like a keyboard drawer. I’ll have to find a way to fix it to the desk though, so I can press the bypass switches without it all falling over.
    I may may also set it up so that the zoom R8 can slide in under the bottom. And it’d be neat if the top level could lift off. That way I could have the top level with my playing-out pedals on it.
    It’s going to be like a Transformer!
  • StavrosStavros Frets: 337
    edited July 2018
    "somebody" ?
    All you need is a guitar and your good to go lol
    Amazing!
    I love my brick
  • Also promising:
