Any suggestions of what order to put these in.On a Boss BCB60?
LozboyLozboy Frets: 80
edited August 2018 in FX
Hi All
 Any suggestions of what order to put these in.On a Boss BCB60.
Starting Input end right-left.
They are all Boss pedals.
Blues Driver
Bassman.
Tremolo
DD6 Delay
Fender Reverb
GE7 graphic
 Thks in advance Lawrence
  • JezWyndJezWynd Frets: 6104
    1. GE-7 (lets you use EQ pedal to boost Blus Driver)
    2. Blues Driver
    3. DD-6
    4. Tremolo
    5. Reverb
    6. Bassman
    You could try swapping DD-6 and trem to see which you prefer.
  • TeetonetalTeetonetal Frets: 7814
    1. GE7
    2. BD
    3. Bassman
    4. DD6
    5. Reverb
    6. Tremolo
    edited August 2018
    2. Blues Driver
    3. DD-6
    4. Tremolo
    5. Reverb
    6. Bassman
    This is the order in which I would list these pedals on eBay :-D
  • MattBansheeMattBanshee Frets: 1498
    If it were me, which it isn't;
    Bassman
    DD6
    Blues Driver
    GE7
    Tremolo
    Reverb
    I am fond of having delay before my main distortion sounds and I find it gives more of a wash.
  • LozboyLozboy Frets: 80
    Keep them coming.Very interesting the ideas on this.Thks
  • ICBMICBM Frets: 72574
    I would definitely not put the Bassman too early on - it's an amp emulator, not an overdrive pedal really. At the very least, you want the Blues Driver before it. Whether to put the GE before or after depends on if you want to use it to push the 'amp' harder (before) or to add more powerful EQ to it or use it as a solo level boost (after).
    Tremolo, delay and reverb go before if you want the sound of those effects in front of (or as if they are in) the 'amp', and after if you want more of a 'studio effects' sound.
    I would probably go
    Blues Driver
    Tremolo
    Bassman
    GE
    Delay
    Reverb
