Q: When recording from your amp DI, is it alot less bright compared to mic'd recording?
fastonebazfastonebaz Frets: 4132
All the various amps I've recorded with via DI have this issue. Wondering if it's just me, my cables or interface etc or actually a common thing.
Cheers
  • ICBMICBM Frets: 72571
    What speaker emulation are you using?
    Without emulation, the DI signal will be much brighter than a mic'ed cab, and not in a good way at all.
  • A lot of amps have a 'speaker emulated' DI output. What they really mean is, they've filtered out the higher harsher frequencies. This leaves you a less bright, slightly muffled output.
    Yes this is what I've experienced generally.
  • When I had a Blackstar Series one amp I often found the emulated DI signal brighter than the mic’d signal.
    Probably because Blackstar pick speakers with no top-end for their cabs :).
    It was vintage 30 loaded
    Exactly - a speaker with no top-end. Contrary to popular belief it is not a bright speaker - it has a huge upper-mid spike which can make it sound harsh, but that's not the same as bright. (Unless you've lost all your high-end hearing :).)
    Blackstar always seem to choose speakers like this, and the Seventy/80 which they fill most of their cheaper amps and cabs with - they seem to like all mids and no real top-end, and a tight rather than loose bottom-end. I think it's a deliberate choice because they're all like that, but to me it's completely the wrong one when the amps themselves are quite dark and tight-sounding as well.
    The V30 works very well with amps like the Mesa Rectifier which have a more scooped tone and a much looser resonant bottom end.
  • Is there anything to be done to make the DI sound brighter and less muffled when recording?
    EQ it at the desk. Re-EQ'ing the amp probably won't help much, since the emulation comes after that.
  • Thanks all
