Taylor Expression System Identification
I need a little help from someone more knowledgeable than I!
I have just bought a Taylor 312ce from 2006. It’s a lovely instrument but the pickup is a little different to the usual. It has the same 3 knobs on the top bout but the battery is inside the guitar, not next to the end pin. It’s a 9v battery not AA. It hasnt got the piezo under the bridge either.
Anyone know what this is? It sounds great.
  • Simon_MSimon_M Frets: 542
    Some investigation later and I think it's an ES 1.2. Still, I'm used to seeing the battery compartment mounted at the end strap pin rather than in the body.
  • ICBMICBM Frets: 72716
    You've got the better version. The tubular AA battery holder is notorious for rattling if the batteries are a bit undersized and sometimes jamming if they're oversized.
  • Simon_M said:
    It hasn't got the piezo under the bridge either. ... It sounds great.
    Good choice. My musical collaborator's 2013 Taylor has the ES2 system. Plug in. Record. No issues.
    Brilliant! Good stroke of luck then. :) I’m going to replace the battery when I put new strings on as it’s been in there for a little while according to the chap I bought it off. I really like the cleanness of the end pin/output jack. Looks much nicer than the chunky plastic AA holder.
