Glass slides, size?
robgilmorobgilmo Frets: 3581
Are there different sizes? How do you know what size to buy?
  • martmart Frets: 5205
    Try, try, and try again.
  • robgilmorobgilmo Frets: 3581
    Online buy, I was in the shop on Saturday and forgot all about a slide, and what difference does wall thickness make? Is it purely feel?
  • fftcfftc Frets: 559
    The Dunlop site have a ring size and slide size chart.
    Decide what finger you want to use and whether you want a knuckle, short or long slide. Measure the finger to get your US ring size and then choose the slide in the material you want that fits.
    https://vidweb.aws.marketlive.com/jimdunlop_vid/text/content/pdp/manuals/Slide_Chart.pdf
    Oooh, coolio, thanks.
    Now , how to choose a finger? I am thinking the ''flip the bird'' finger as its my least used finger, any ideas? is there a preferred finger? I guess that's a silly question but I have to ask, as you can tell I dont play slide..
  • FunkfingersFunkfingers Frets: 14571
    edited September 2018
    Weight.
    I like the replica Coricidin bottles. Probably due to my Duane Allman obsession.
    The most common choice is probably to wear the slide on the little finger and support it using the ring finger.
    Nerve damage means that my fingers do not always co-operate. I often use the ring finger.
    Wearing the slide on the middle finger should free up the ring and little fingers to fret notes above the slide. Sonny Landreth is known for sometimes fretting notes below the slide.
    So from what I have gathered (you tube) , weight = sustain? Glass = mellow tone, steel = brighter tone but less sustain than glass, am I barking up the right tree?
  • GrunfeldGrunfeld Frets: 4045
    Not just finger size but slide length.
    I am never going to impersonate a proper slide player but that's why the half-length slide works really well -- it's easier to play I think.
    If you just want an occasional bit of slide in a gig it's really handy.
  • bbill335bbill335 Frets: 1389
    sustain is to do with technique, not material
    Half length does sound interesting but I think setting ,myself up with the basics first before exploring other avenues would be best. I have just measured my flip the bird finger at 80mm, that's at the base of my finger, its fattest part, that 10mm off the Dunlop scale, am I missing something?
  • poopotpoopot Frets: 9099
    Watch Blake Mills doing his thing in this vid.
    should give you an idea how to wear your slide ;)
    https://youtu.be/kH1ZxoEkv84
    Ive just been watching Justin saying the same thing, quite relieved , I thought I might have unnaturally swollen fingers! So resting ontop of the first knuckle. Those pill bottles, are they not quite loose on the finger?
  • pumkinpumkin Frets: 136
    Try these people .... all you need to know and great service
    http://www.diamondbottlenecks.com/BestOfTheRest.html
  • crunchmancrunchman Frets: 11470
    Different people use different fingers.
    Ring finger seems most common, and it works for Derek Trucks who is probably the best slide player on the planet. I use my middle finger, which seems to work for Bonnie Rait and Billy Gibbons.  I've seen people using their little finger as well.
    A couple of people have said some good things.  The length of the slide is definitely important.  It makes a big difference to feel.  If you want to play in standard tuning, then there isn't any point in getting a long one, as you won't ever be playing all the strings at once.
    +1 on Diamond Bottlenecks.  I've got one of theirs that is far better than any of the Dunlop ones you see in guitar shops.
    This is great and is made from a proper bottle neck:
    No ceramic/porcelain options though. I know the OP said glass but that might be due to not knowing about all the options, and ceramic is definitely a preference for some folks.
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    Wis'd. I went on a blues course last month and he had a table set up there one day, which I visited with my guitar after my fourth slide workshop of the week. It was a great few minutes and had a great customer service/goldilocks experience.
    I tried one, played something and a voice behind me asked how it was. I said "too light" and before I could get the thing off, another appeared over my shoulder and the voice said "Try this one". I did, it was too wide. "This?" Too narrow. "This?" Not long enough. "This one?" It went on for about 10 slides, which he was picking out with lightning speed and I went going back and forth between a few, to make sure until I found one that suited me.
    FWIW mine's on the little finger so I can play riffs with my first 3 fingers, and can also use my middle finger behind/under the slide to play a minor chord.
  • I never know how loose the slide is supposed to be on my fingers. Should it stay put without the supporting finger either side? Should it need me to slightly bend the knuckle join to keep it on?
    When I measure the size of my fingers, according to the charts, I need a fairly big size, but I have a Derek Trucks signature slide and find it just feels a little loose and uncontrolled on my ring finger.
    Oh, yes - when I play, my ring finger supports it.
    You should be able to take it off (obvs) but you'd be surprised after a few minutes playing when one that goes on OK doesn't always come off... as live updates from @noisepolluter on the bus to A&E confirmed (true story). :/
