Adding a Floyd nut to a Gibson-style angled neck
Looking for some advice, I'm thinking of adding a Floyd to a guitar with a Gibson scale, it's what I'm comfortable with.
What's holding me up is the nut.  The standard Floyd nut would easily overshoot the fretboard and I assume some sort of fill would be required.
Is this even possible? Or perhaps I'd be better off just getting a neck made for my Wolfgang?
Any advice appreciated, thanks :)
  • ICBMICBM Frets: 72774
    You could use a Kahler-type behind-the-nut clamp, with the stock nut.
  • Thanks ICBM, I'll look into it :)
    As used by Robert Fripp. :)
    NOTE: This modification will require the nut to be changed. The strings need to run in a straight path over the nut and through the clamp.
    The other alternative is locking machineheads.
  • AlvinAlvin Frets: 416
    edited September 2018
    Locking tuners are not effective in replacing a locking nut .   They should really only be thought of as a way of quick string changes or allowing fewer wraps around the post , they can add to tuning stability but really that is if you don't wind your strings on the tuners properly to begin with  .  You can of course use a floyd without the locking nut but ideally you do want the straight string pull and Les Paul types do have tuning issues because of the string angles as we know . You can  use floyds without the strings clamped if you have the straight string pull also , it just depends on the guitar i do this quite often and they sound and play fine for me .Others will disagree but as i said ,it depends on the guitar , if you don't have straight string pull the strings will want to work there way up the (v shaped ) slots so then it isn't ideal.
       Your first idea is very possible and i have just done this , you could just extend the nut shelf with a piece of maple , you will only be able to tell from the sides depending on how you blend it in (if you even do this) .   It is surprising how small a piece of wood you will need to do this , i just bought a couple of maple drumsticks and got i piece close to shape , glued it on , blended the shape in and then just levelled the shelf .  The screws that go through the nut  will only be going through the thinnest part so the new piece is really just a ledge for the nut to sit on and will barely be holding the screws.
    No, it doesn't. You can just flare out the grooves while keeping the same notch in the front face.
    I fitted quite a few of these in the 80s :). Never changed a nut, that I can remember...
