Lower saddle and fit strap pin - a job for a luthier?
I've got a sub £1000 Gibson acoustic that I want to add a strap pin and lower the action a bit. Would that be a job for a luthier or something I'd take to the grunt at my local shop like I would for an electric setup?
  • ICBMICBM Frets: 72675
    Depends how good the grunt is... some are fine. Some 'luthiers' aren't.
    Two important questions:
    Does it have an undersaddle pickup? If so lowering the action is usually a more demanding job than if not, assuming it's the saddle that needs to come down as well as the nut and/or relief.
    Do you know where you want the strap button fitted? There are three common positions (two on many guitars, but a Gibson will take the third) - on the back of the heel; on the heel pointing directly up the neck (not possible on guitars with a pointed heel); or on the underside (treble side) of the heel. Be careful that whoever fits it doesn't just whack it on the back of the heel, if that's not where you want it - a 'luthier' did that for someone here. It's not a good place usually.
    NB, I'm a guitar repairer with over thirty years' experience but I would never call myself a luthier, because in my opinion that's someone who *builds* guitars, and I don't. But I can certainly fit a strap button and lower the action correctly.
    It does have an undersaddle pickup. Is that more demanding? I thought you still just pulled out the saddle and shaved it down. Or does it need to be shaped in some way?
  • AliGorieAliGorie Frets: 308
    saddle base HAS to be dead flat to make full contact with the US element otherwise ya lose out on vibration transfer  - resulting in  un balanced sound hess.
    Yes, as AliGorie said - more demanding because the bottom of the saddle must be dead flat and square, or you will get uneven string response.
    The best way to do that is with a sanding board - a flat board with sandpaper glued to it that you move the saddle on, not the other way round. You can do the bulk of the cutting first with a saw or file, depending on how much needs to come off.
