Using 2 delay pedals
vizviz Frets: 10720
What interesting things should I try out? I've got a Boss DD5 and an Ibanez AD9.
  • If I use two delays most of the time I have one for slapback and one for a more conventional echo or else one on a 1/8th and one on a dotted 1/8th.
  • vizviz Frets: 10720
    Yep I've tried a few 2/3 rhythms. I think i need two digi delays to explore it properly because the analogue one sounds too nice and natural. I'll try the slapback idea.
    edited April 2014
    This....
  • ICBMICBM Frets: 72597
    I like to use an analogue delay set fairly short (obviously... ;) ) with a low number of repeats followed by a digital set long - either a multiple of the same delay time or not - with a higher number of repeats so you get a syncopated repeat pattern... quite U2-like. You can make it even more interesting by having the analogue in front of the amp and the digital in the loop, too - that gives you more options.
    Hey thanks all of you, ok i'm making progress. Doesn't sound brilliant though but i'll carry on fiddling.
  • BucketBucket Frets: 7751
    I've got an MXR Carbon Copy on my big board, which goes through the FX loop. I really want one of the cool retro-looking Ibanez Echo Shifter delays to put through the front of the amp on the same board. That'd be ace.
    I like to make it sound like ahhh can play fasterst.
    They do, very occasionally, appear on eBay, I paid for one a while back and the bloke never delivered.
    I paid £30 ;) hence why he never sent it.  I got a refund luckily.
  • littlegreenman < My tunes here...
  • mike_lmike_l Frets: 5700
    My old board had a short into a long delay if/when they were on together, actually (IIRC) not set too differently from how littlegreenman has his ^^^. With a chorus in front of them. The long was set for a long solo delay (a bit like Dave Murray) and the short was set as a slight expansion for a clean tone, which worked really well with the chorus set quite lightly.
  • Not actually my pedals, but it is how I set mine up. I have the long delay at double the time of the short so you get the short delays repeated at longer intervals, if you get what I mean? Totally stole the idea from a certain bald guitar wizz! ;)
    I'm talking about the new ones, which are about £100 and look and sound awesome. Analog with tap tempo, yes please :D
  • Those new echo shifters do look smart
  • monquixotemonquixote Frets: 17666
    Andy Timmons has 2 delays on all the time I think.
  • I love the cascading repeats you get from using 2, it's a bit nice :)
    I do get this, mine were set pretty much like that. Short was roughly half the long, but slightly out for a slight chorus effect, with out having the chorus on.......
    edited April 2014
    Ok. What I've done is:
    Guitar>TS9>Carvin Legacy 1>Loop>Boss stereo chorus, splitting into two signals:
    >Ad9 (short)>Carvin Legacy 1 return
    >DD3 (long, analogue setting)>Hum Eliminator>Carvin Legacy II return
  • HeartfeltdawnHeartfeltdawn Frets: 22251
    One short going into one long = yummy.
    Then do the same with reverb. One short going into one long is awesome.
    Oh man, I need one.
    edited April 2014
    Oh man, I need one.
    You and me both :D
    There's a demo or two of it floating around and it can do some nice "normal" sounding delays, but some pretty out-there stuff as well if you need (go to 1:50 for example). And the tap tempo thing is great... I will definitely be having one at some point.
    Fuck me, it sounds even better than I remembered.
