NBAD - Ashdown content
LegionreturnsLegionreturns Frets: 7965
edited October 2018 in Amps
Thanks to the ever knowledgeable / crack dealing enabler in chief* @Bridgehouse , I am now the proud owner of the above Ashdown ABM 300 1x15.
Jees it's ballsy and full of thump! Look forward to taking this somewhere I can let it roar!
*delete as applicable
    Knowing what you paid, naysayers aside, it’s a lot of amp for the money you paid ;)
    There’s one of them in one of the rehearsal rooms I use from time to time and it’s more than capable of doing it’s thing.
  • I think karnivool used ashdown for a long time and can't argue with that bass tone. Super under rated brand imo
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • ICBMICBM Frets: 72740
    They do actually sound good.
    And at least if you got it cheap you can afford to replace the speaker when it blows :).
    Ashdown blue cone speaker out of one of these on the right, proper speaker on the left...
    I have replaced quite a few of them - I just use whichever 8-ohm Celestion or Eminence rated for at least 300W Lean Business are doing cheap that week.
    It's also worth putting a piece of dense foam rubber under the power amp board to stop it vibrating with the weight of the heatsinks - that will stop a lot of the solder joint cracking problems. Be careful not to touch the heatsinks with the amp powered up - they operate at a high enough DC voltage to give you a nasty surprise!
    Funnily enough at rehearsal tonight I was playing into the rehearsal rooms Ashdown 300... into an 8x10.. it sounded rather epic.
    Oh, and I played the fretless all rehearsal and got away with it. Crikey.
  • JezWyndJezWynd Frets: 6121
    That’s brave of you, but then, once bitten it’s hard to revert to fretted. Do you have markers for each fret? Without them I doubt I’d risk playing against other instruments atm.
    Lines on the edges of the board - which means I’m semi cheating, but it isn’t fully lined tho
  • These are killer amps, and selling for silly money second hand. Love the contour button, the EQ curve works so well on either a P bass or a Rick 4001. I bought an EVO 2x12 a few years ago, and found an EVO II 2x12 for even cheaper - having two amps (one for gigging, one at the rehearsal room) solves the problem of lugging them around, and still cheaper than buying a head and cab...!
