Let's argue about this
TravisthedogTravisthedog Frets: 1847
Ol pedal order can o worms
Simples - which order would you put these in - currently they run muff - Jrad - spark
https://imgur.com/a/vorOmoI
Discuss
  • Modulus_AmpsModulus_Amps Frets: 2595
    whichever works for the sound you are after, end of.
  • whichever works for the sound you are after, end of.
    liking your style
    liking your style
    I take it he does not "stack" them like that?? he is a one at a time sort of guy?
  • He is but he uses the spark boost to kick more gain out of the JRAD
  • p90foolp90fool Frets: 31656
    Depends whether you want a gain boost or a master volume boost?
  • DrBobDrBob Frets: 3006
    See I’m new to fuzz units so I don’t know what the sketch is with them but I thought that accepted wisdom was low gain into high gain so wouldn’t that mean Spark into JRAD ?
  • Its sounding pretty bloody good the other way round though bro
  • ICBMICBM Frets: 72575
    I find ‘accepted wisdom’ is wrong and the right order is determined by EQ - more midrange into less midrange, regardless of gain.
    The position of the boost depends on whether you want to increase distortion or volume.
    The Big Muff is very scooped and if I use a boost it’s to increase volume, so for me it would be overdrive > Muff > boost.
    But you may have different preferences or purposes. There are only six combinations of three pedals, try them all...
  • Muff of the board, in a cupboard, where it belongs.
    But if you must, you want something mid-heavy that can drive the Muff and make it sound better, then something after to make it louder and fatter. Plus I always use clean boosts as "make fuller & louder" boxes, I'd probably go JRAD - Muff - Spark.
    But I'm happy to admit I don't think I'd actually choose any of those pedals, let alone use them together.
  • I always run low gain stuff at the end because they're generally heavier in the mids so I feel like the EQ change/boost is more dramatic. If I run a boost into a fuzz I just seem to get the fuzz, but more of it; running it after changes the character entirely.
  • jdgmjdgm Frets: 852
    Boom.
    Have you tried Spark in the middle?
