What shall i do with my broken amp?
shaunmshaunm Frets: 1633
I have a Laney Lionheart 4x10 which no longer works. There is volume but only through the reverb. It doesnt work if the reverb is not up full and even then the sound isnt properly there.
So, that leaves me with an amp that isnt really up to much. It wasnt an expensive amp and i dont want to throw good money after bad. Plus I have another one of these amps which works perfectly.
What i am thinking is that i have four working speakers which are decent Jensons P10-R speakers. I was thinking that I could get a 4x10 cab made with those speakers? If so would they be suitable to go with a JTM45?
Would a 3x10 cab work and maybe put one of these Jensons in my 68 Princeton? Or would that be a poor choice?
What would you guys do in this situation?
  • ICBMICBM Frets: 72619
    Get the amp repaired. It may not have been that expensive, although I’m not sure compared to what... in my opinion they weren’t cheap. Repairing it should be cheap and easy - if I remember correctly the reverb is in parallel with the FX loop and the main dry signal path... has the amp been modded to a series FX loop? If so, the fault is probably either the FX loop jack contacts or a bad solder joint related to the mod.
  • TenebrousTenebrous Frets: 1332
    If I were in your situation, I'd try to fix it myself. If you pull it off, great! If not, well, salvage the speakers & sell the amp as broken.
    (I do have an interest in fixing things, though).
  • DJH83004DJH83004 Frets: 196
    If the amp is in good cosmetic condition, it is definitely worth having it looked at, the fact that you are getting output via the reverb path, then the issue is with the dry signal path, so there is a good chance that the first gain stage is good and the output stage is good, so its just the bit in the middle :) .Seriously it doesn't sound like a difficult fault for a good amp tech to find.
  • normula1normula1 Frets: 640
    Check the fx loop. I had a similar issue with mine and the sockets just needed a clean. The reverv circuit is in parallel with the fx loop which is why you still hear it...... Or I'll take it off your hands for a fiver
  • Viking funeral!
  • octatonicoctatonic Frets: 33839
    Er-ly in the morning....
