99 starting for 1975
00 starting for 76
06 starting for 77
1975/6/7 and they are easy to identify, yet a quirky system that bares no relation to the actual year
Yet by 1978 they created the 8 digit number with 1st and 5th giving you the year, which is logical and easy to follow
Looks like the above guitar is a 1976 model
That pics shows a split between 2 tuners and looks like changed tuners at some time - Wish the pic was better - Maybe a repair and/or re-spray on this one
Pots might be found on a later serial number - ie 77 pots on a 78 guitar, but obviously never earlier
Yes most of the ones I've seen with impressed serial numbers still show the 'made in USA' tag as well
Agree it does not look right
Sorry guys 13777517 is a wrong number it should read 1377517 - this indeed is the 17th week of 1975.
As for both V's there is nothing odd about the numbering on both and are both original serial numbers.
Gibson used 6 digit serial number in the early produced V's in 74/75 for the 2nd reissue of the Mahogany V placed in a stamped decal and - 102907 is a legitimate number but they bear no resemblance to the current dating system which was introduced in 1977
1970-1975
Despite being purchased by the Norlin corporation in 1970, Gibson maintained the same confusing 6-digit serial system through 1975, meaning instruments with the same serial number could be from either the ‘60s or the ‘70s.
Fortunately, there were two notable changes to the entire lineup that occurred during the transition that make differentiating ‘60s and ‘70s Gibsons straightforward.
This guitar falls into a time of serial number conversion.
Then also in 1975 Gibson introduced to the oval decal (along with the serial number), the made in the USA and the model.
At about the same time Gibson also introduced the stamped serial number with "made in the USA" on the back of the headstock but not in an Oval stamped decal.
Then in 1976 Gibson introduced a Limited edition with an 8 digit serial number decal transfer placed in the Oval stamped decal.
Then in 1977 the current numbering system was adopted.
Hope this helps
before the current 8 digit serial numbering system came into play- you would only ever buy Gibson guitars later than 1977?
You would never own a 67 V?
