Dumb question about internal wiring...
The f**ktard who rewired my MiM Strat cut the wire that goes to the cable jack from the pcikup cavity so short that sometimes when I plug the instrument cable in it pushes the wire off the solder joint.
Third time it has happened, I need to replace these wires and alow a longer bit.
What specification of cable do I buy?
  • ICBMICBM Frets: 72606
    Any fairly small single-core shielded cable is fine. The original wiring might be two separate wires, but a shielded cable is better.
  • FuengiFuengi Frets: 2850
    Thanks @ICBM looks like it's a shielded cable replacement. I'll grab some.
