Valve head amp for 112 cab - home use only
LordOxygenLordOxygen Frets: 319
edited December 2018 in Amps
Having lived with my Marshall DSL5C combo for a perhaps 5 years I fancy a change.
Decided I'd like a 112 cab (or maybe a 212 if my other half will agree to it) and a valve head amp - I only play at home but have a detached house so can make some noise every now and again.
Things I need are
  • Facility to reduce output to 1 watt or less. (no upper power limit, lower limit is 1 watt in standard mode)
  • Effects loop for pedals
  • 2 channels - footswitchable
  • Jack of all trades (good clean channel, powerful high gain sound, think Metallica)
FWIW I think Marshall are fools for not producing a DSL5 head amp, so far my shortlist contains the following
Blackstar HT5RH (doesn't have 1 watt option, and it is now discontinued)
What else should be of the shortlist that meets my criteria???
Budget is up to £500 for the amp new or used.
Cheers
  • ICBMICBM Frets: 72620
    Used Yamaha THR100HD.
    No 1W option - the lowest is 25W - but it doesn't matter since you can just turn down the volume control.
  • LordOxygenLordOxygen Frets: 319
    Sorry, should have said proper valve amp - don't want modeling amp, not my thing. Have edited the tread title.
  • ecc83ecc83 Frets: 1639
    Still on the website, will check some shops. You can make a power soak for a Five very easily with a "50w" L pad.
    Dave.
    You should try a THR100, you would be very surprised... I was. Totally different from the THR10.
    Dave.
    Blackstar told me in an e-mail last week production has stopped, I expect there's a mk2 coming during 2019.
    Most shops ( pmt andertons etc) dont have stock.
    I can get a used one but was hoping this thread would point me towards 2 or 3 alternate valve amps i can try.
    Also worth trying an Orange Brent Hinds Terror. Goes down to 1/0.5W with the 'Bedroom' switch.
  • PhiltrePhiltre Frets: 4175
    edited January 2019
    Peavey Classic 20 Mini Head. 20w / 5w / 1w, FX loop, USB out, 2 channels.
    Andertons don't have them is true but PMT, GAK and Thomann do.  You might consider an amp plus a power soak becuase 1W is still pretty loud through a decent speaker. That said, smashing almost any amp down to milliwattts is never going to sound great.
    Dave.
  • John_AJohn_A Frets: 3775
    Engl ironball covers everything very well indeed, 20,5,1w or silent for headphones use or recording via emulated out, very versatile, foot switch for reverb, channel boost and reverb
    Thanks, ill have a read about that and the peavey mentioned.
  • Check out the Hughes & Kettner Tubemeister 18, has all the facilities you seek.  I play mine into an Orange PPC112 and I bought it from Reidys a few months ago when they were doing it for £339, has 3 year warranty too when registered.  It's at £399 now, still a good deal.
    https://www.reidys.com/pr/guitar-amplifiers/hughes-and-kettner-tubemeister-18-head-18w-13732/
    Cheers, that's another one to consider.
  • McTootMcToot Frets: 2042
    Jet City Custom 22. Doesn't have a power reduction but doesn't need one. You can get clean to seriously saturated at low volumes. Clean at high volumes is more tricky but can be done and there are loads of mods available. Cheaper than lots of fx pedals...  If you're anywhere near West Sussex you can try mine through a 1x12 cab. You can also compare it to my Marshall origin 20H which has three power settings but doesn't do metal (without a pedal)...
    Beauty is in the eye of the beer holder
    My trading feedback  - I'm a good egg  ;)
    Thanks for the offer, if I was closer I'd take you up on that, I'm north Oxfordshire.
    The jet city heaf has to be a contender as well.
  • andy1839andy1839 Frets: 2197
    PRS MT15?
    Sweet cleans and screaming gain at low volume. Great FX loop too.
  • andy1839 said:i
    PRS MT15?
    Looks ideal on paper, thanks.
    Glad I started this thread, few amps here I wouldn't have considered / didn't know they exisited.
    andy1839 said:i
    PRS MT15?
    I've just got one, really is a Great little amp. It doesn't go as low as 1w, but can be switched to 7w, but it really does sound good at talking volumes.
    Shame the clean boost isn't footswitchable, and doesn't have a gain control on that channel.
    Only those two criticisms really.
  • andy1839 said:
    andy1839 said:i
    PRS MT15?
    How would you describe the clean channel sound? Fender type clean or Marshall...or ??
    andy1839 said:
    andy1839 said:i
    PRS MT15?
    It's more fendery to me.
    It'll never be a Princeton or Twin, but it's a good pedal base and even with just some chorus and reverb it's a big sound.
    Dave.
    I guess they've been replaced by the 10w amps.
