FS Jackson Soloist Custom 1988 Sunset graphic SOLD
Here's a great guitar, a piece of history even, in good condition.
1988 custom made Soloist (serial J4432). Original specs: J-200, J-200, J-50BC & JE-1200 electronics, non-recessed JT-6 bridge (pictured with a Schaller here, my preference, JT-6 is fully functional and is included with the guitar), ebony board, maple neck, poplar wings, sunset graphic. Original hard shell case.
Condition good - couple of dents on the body, a bit of binding has been repaired on the tip of the headstock and there is a fairly long (12-13 cm), but hair thin crack running down the fretboard. The board appears to be absolutely stable and the neck is straight and frets are great.
Item in Helsinki, Finland. Shipping around 40 pounds or so, I can check the accurate quote for you.
