Recommendations for new wiring harness for Epiphone 335 Dot?
PhiltrePhiltre Frets: 4175
edited January 2019 in Making & Modding
Can anyone recommend wiring harness for an Epiphone 335 Dot?
So far I've found these:
https://www.sixstringsupplies.co.uk/product/es335-harness
The last one looks pretty slick if more expensive.
Or is it worth buying separate components?
  • peteripeteri Frets: 1283
    I got the last one as a harness on my vintage 345 (I wanted to pull the varitone out).
    Very happy with it, came quickly, very well made and sounds great.
    Recommended!
  • PhiltrePhiltre Frets: 4175
    Recommended!
    I've just ordered one from @sixstringsupplies ;
  • sixstringsuppliessixstringsupplies Frets: 429
    thanks for your order @Philtre shall get that out ASAP.
    Thanks and glad you liked it @peteri did you end up filling the varitone hole with a blank pot/control knob?
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
  • FunkfingersFunkfingers Frets: 14572
    Some of the pickup and guitar builders on this forum offer a complete harness assembly service.
    Hi - yes I did, to be honest I nearly didn't because it looked impossible to get in.
    But a good tip from Hugh to use dental floss made all the difference and looks great so glad I did.
    Plus I can pretend to make tone changes with it! ;)
    Now I'm wondering if I should have ordered some new knobs as well. Will the old ones fit the new pots?
    The Epiphone knobs are unlikely to fit the CTS pots. It is possible by bending the splines of the pot shaft closer together but not really worth the risk.
    I'm quite low on control knob stock, have a look by all means (they all fit) Otherwise AllParts UK will have all you need regarding control knobs to fit CTS pots
    @sixstringsupplies Thanks, will check it out.
    edited January 2019
    So, I took the plunge and fitted the harness into the Epiphone Dot. Pot holes needed widening to 10mm but that was an easy job with a stepped drill bit. Bit of a faff pulling stuff through the F-hole (strings get tangled), but the rigidity of the harness and pots made that a whole lot easier. Combined with the SD 59 pickups, it's a great sounding guitar.
    Many thanks to Ed at @sixstringsupplies for a great product and service. Recommended!
    many thanks @Philtre I hope the switch tip has arrived by now too. Good work on installing it too.
    Arrived yesterday. Looks and sounds great!
