Sorted (possibly) Update - Recommend me a low gain transparent drive please
paulnb57paulnb57 Frets: 3065
edited January 2019 in FX
Marshall Origin 20 Combo, sounds great clean, but has very little, if any, drive at low volume, so Im looking to buy a transparent, low gain drive pedal, to give me that just breaking up kinda tone, maintainig the core sound.....
Recommendations please....not too spendy.....
Ta!
  • FuengiFuengi Frets: 2850
    Thorpy Peacekeeper. Does exactly what you want superbly.
  • simonksimonk Frets: 1467
    Timmy. Always Timmy.
    Liquid sunshine
  • p90foolp90fool Frets: 31655
    My standard response is Nobels ODR-1, you can set it pretty much the same as the amp then add gain.
  • fandangofandango Frets: 2204
    +1 for the Thorpyfx Peacekeeper.
  • SassafrasSassafras Frets: 30306
    Boss OD-2.
    Plentiful and cheap.
  • TheMarlinTheMarlin Frets: 7929
    Timmy.
  • Sassafras said:
    Boss OD-2.
    Want to try one of these, what’s the difference between the OD-2 and OD-2r
  • PhiltrePhiltre Frets: 4175
    Timmy, Jan Ray ($$$$), Amp 11, BD-2, King of Tone, Prince of Tone, OCD
  • BabonesBabones Frets: 1206
    Klone. eg Frederic Effects.
  • WazmeisterWazmeister Frets: 9605
    THE best 'transparent' low gain, imho, is the Greer Lightspeed.
  • KebabkidKebabkid Frets: 3324
    Look at the Liquid Sunshine for sale on here - no affiliation OR more recently, I found the Fulltone Fulldrive 1 to be very good in the lower registers but then surprisingly, so's an OCD, which becomes almost Timmy-ish at the start of its gain register.
    I think an OCD has already imposed its own sound on an amp quite heavily even before you add gain, I'd never describe it as transparent.
  • ICBMICBM Frets: 72574
    Marshall Bluesbreaker.
  • The only pedal I've found that doesn't alter the EQ of a signal before passing through to the amp is the TC Electronic Spark Boost. The Timmy, which many people say is transparent, definitely changes the sound when adding dirt, however much you fiddle with the EQ.
  • stickyfiddlestickyfiddle Frets: 27198
    The LS on here is my old one - I used to use it for exactly what you're describing. Just the same basic tone with more "hair". Cracking pedal for that purpose.
    Or go Klone if you want something with a bit more "roundnessy oomph"
  • AlexOAlexO Frets: 1099
    Xoctic RC
  • paulnb57paulnb57 Frets: 3065
    edited January 2019
    Thanks for the replies folks, theres loads to look at...
    @ICBM I must admit I was considering staying in house and trying a Blues Breaker pedal
    Bloody pedals are such a minefield!......
    Edit...as a starter for ten, I've ordered a Blues Breaker pedal, cheap as chips, virtually disposable, I'm sure more will follow!....
    These are my findings too
    edited January 2019
    Mmm..I'd say the same of the Nobels but I think they'd both work. The Greer is probably the best one mentioned here, but also the most expensive
