Nashville style Parts-a-Caster.
exocetexocet Frets: 1964
edited January 2019 in Making & Modding
After 4 years, its finally complete. Nearly gave up on this one because I'd made such a mess of it.
Thanks to Jon @rexter for the excellent respray and remedial work / routing for Nashville config.
Thanks to Jonathan @FelineGuitars for the finishing touches and setup.
USA CG Neck (Roasted Maple)  and body.
Callaham hardware.
Electric City Pickups (12 Gauge Semi) - 5 way switching for Strat Tones plus Tele Bridge & Neck.
https://i.imgur.com/kuJWKp4.jpg
https://i.imgur.com/sl1QfwX.jpg
https://i.imgur.com/g1U3Vg0.jpg
https://i.imgur.com/FKJJ192.jpg
https://i.imgur.com/kewfn8J.jpg
https://i.imgur.com/84ImOLM.jpg
  • longjawlongjaw Frets: 423
    Lovely flame on the neck!
  • BigMonkaBigMonka Frets: 1783
    That's a stunner, the neck and body colours go together so well.
  • JezWyndJezWynd Frets: 6112
    That looks fabulous, congrats on seeing it though to completion. I've been thinking about trying a Nashville tele, does the middle pu change the fundamental tele sound much?
  • exocetexocet Frets: 1964
    Depends on how you wire it and which pickups you use. Some implementations on "Nashville Style" miss out the signature Telecaster tone e.g. Neck ad Bridge in Parallel. I wanted Strat tones (2 & 4) AND Telecaster tones so I had to use a "Super Switch" - 5 way, 2 pole (not the standard Strat Super Switch which is 5 way, 4 pole). The 2 pole version is slimmer in order to fit into the available cavity.
    I don't think that the middle pickup changes the standard Tele Tones but if I'm honest, I'm not 100% sure of the pickups that I've installed....think I'm going to experiment a bit with different Neck and Bridge p/u's.
    Thanks for the info, your switching choices are excellent, should be a really flexible instrument. It’s a beautiful guitar, that neck looks amazing and I like your take on a logo.
    JezWynd said:g66
    Thanks for the kind words. The Logo was not my doing....It's a standard option with USA Custom Guitar necks, its basically their logo routed and filled with epoxy resin. I daresay they could engrave anything you like, its all done with CNC kit. Playing my 1st gig with it on Friday night....usually if i'm limited to one guitar, I play a Strat.
