Guidance on Choosing A Fuzz Pedal!
Hello!
So I've decided to buy my first fuzz pedal and t be honest, I'm extremely unexperienced with the varieties of fuzz pedals (although I play a lot of metal). My inspiration to buy a fuzz pedal is mainly from guys like Hendrix (where he rolls down the volume while using the fuzz face) and Gilmour (soloing). But I'm also looking for a fuzz pedal that can also do some Zeppelin and Sabbath (to which I think is just a normal fuzz).
I've seen online that one of the best for Gilmour stuff is either the standard big muff or the green russian. For hendrix, I'm assuming any variation of the fuzz face or Dunlop's "Authentic Hendrix" should put me in the right tonal direction for his sound. I'd really appreciate if any of you could advise me on any fuzz pedal that could suit my needs.
Also, there's a fuzz pedal that I've been seeing on instagram pages recently; its the AC Noises Esplora. Does anyone have any experience with it? If so, could it cover the bases I'm looking for?
Thanks in advance!
  • Winny_PoohWinny_Pooh Frets: 7838
    edited February 2019
    The Hendrix tone only works into a loud Marshall IMO, into a clean setup your fuzz face will sound raspy, nothing like what you expect.
    Similarly with Gilmour there is a pedal and signal chain that smooths the edges off and takes alot of work to duplicate.
    If you want a Gilmour lead tone then get a Skreddy Lunar Module, brilliant. Smooth and fat.
    For something more riffy (where the top end is raspy but has low end crunch) try the Suhr Rufus (one in the classifieds) for higher gain. Its fairly controlled.
    Or for more vintage-y any one of the boutique fuzz faces.
    For lower gain riffing try something like a Hudson Broadcast or Harmonic Percolator clone (Catalinbread karma suture/frederic effects http://www.thefretboard.co.uk/discussion/149712/fs-fredric-effects-utility-perkolator-and-deeply-unpleasant-companion-last-of-their-kind-sale#latest ).
    For something more messy like White Stripes or Black Keys get a Fuzz Factory or Shin-e fy2 (Frederic effects)
  • Check out the new Triangle Big Muff reissue. It'll probably do Gilmour better than the others, and is likely to be the closest muff to a Hendrix sound too.
  • Fishboy7Fishboy7 Frets: 2228
    Earthquaker devices hoof reaper covers a lot of bases and includes octave .
  • Fuzz is a minefield. I like plenty of gain (usually rules out standard fuzz faces) and I like plenty of cut and not too smooth (rules out most muffs) but not ear-piercing treble (rules out the Carcosa). I generally like a tone control of sorts and some interaction with the volume knob.
    If I was recommending a do-it-all starting place for fuzz I’d say start with a Zvex Mastotron.
  • I’m it sure there was ever any fuzz in Sabbath, not that much in Led Zep either I think. Although yes they certainly sound fuzzy at times.
    I’m not sure I’ve ever quite figured out fuzz. It also tends to be amp dependent and vintage styles will need to be first in your pedal board chain. Something modern with a level of EQ is probably a good idea otherwise it can just disappear in a mix. The Magnetic Effects White Atom gets a lot of love on here as a versatile fuzz without some of the quirks of vintage designs
    http://www.thefretboard.co.uk/discussion/123104/magnetic-effects-white-atom-fuzz
  • ...and FWIW I have one of these, partly as it cleans up well which is not true of all fuzzes and it’s also modern, no fuss like the White Atom.
    https://youtu.be/DcWzGkh6vOo
    White Atom:
    https://youtu.be/0UKrW_whUl8
  • soma1975soma1975 Frets: 6924
    Get a fuzz face. Seriously. If your main reference is Hendrix just get a Fuzz Face and go from there. Nothing else quite does what it does, and yet it can get almost muffy, almost tonebendery etc.
  • ricorico Frets: 1220
    Black arts toneworks do some great muffins style fuzzes
  • CorvusCorvus Frets: 2970
    If the amp doesn't dirty up a fuzzface type can work well into a Marshally-sounding pedal; though not all work great at that.
    As above Lunar Module is a great fuzz-face type pedal that works into clean amps. There's other good sounds in there too.
    If you wanted a ticket to Planet Muff without breaking the bank there's someone who sells a range of types on ebay, I got a Black Russian to try out as a flavour and it's very good. Cost £25. OtalgiaFX is the name.
    Re which Muff in particular I think DG boosted Muffs or ran them into other dirt, and probably had more of them than Ron Jeremy.
  • tone1tone1 Frets: 5198
    Tis true... I’ve just got  a Cornell Fuzz face and have been A/B with a muff... Fuzz face cleans up better and does a good enough Muff impression... I’ve never tried a Tonebender though
  • lukedlblukedlb Frets: 488
    Thorpy veteran silicon. It does fuzzface, of course but there’s so much more under the hood. Fantastic overdrive. And there’s the treble booster side too.
    All I play is Hendrix and the veteran covers his silicon years well.
    Tonebenders are related to fuzz faces but a lot more aggressive and without the sparkly clean up clean you get with a fuzz face rolled down. A great sound but for me don't really do the Hendrix thing.
  • JD50JD50 Frets: 662
    I'd recommend the Deluxe Big Muff, very tweakable does Muff and beyond , also cheaper than anything else with all the features.
  • Seriously! buy a used Boss FZ-2 two modes of fuzz madness and a great clean boost
  • https://youtu.be/Ssr_a9atxzU
    The grin on Andy’s face made me buy this
  • Th4fonzTh4fonz Frets: 261
    Ive been looking at fuzzs also B  What about one of these.
    King tone Mini fuzz
  • NorthernStompsNorthernStomps Frets: 398
    I seem to spend my life recommending the Magnetic Effects Black Moon at the min. Ive got a couple in stock and one on my personal board and it sounds great. Based on a fuzz dace but sooooo much more flexible!
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • crunchmancrunchman Frets: 11487
    How have we got this far without anyone mentioning the Thorpy Fallout cloud?  It's a great pedal.  Maybe not so much for the Hendrix type stuff, but a great Muff inspired pedal.
    Fuzz Factory.
    With a bit of patience and determination you can get it to sound like most of the different fuzz types. Not much good for adjusting on the fly since the controls are very sensitive but it's a lot of fun.
  • TateFXTateFX Frets: 114
    It's a very hard question to answer I think I've got over 10 fuzzes at last count.
    It sounds like you're after a modern take on the Fuzz face really, Id suggest the ThorpyFX Veteran and the Magnetic Effects Black Moon.
    The new EHX reissues series gets an honourable mention.
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
