Board power help question
HootsmonHootsmon Frets: 15980
I am in the process of changing out my PP2+ for a cioks dc7 and will have to run a splitter cable in two of the cioks outputs so i can power four pedals from two outputs
Is there an obvious pairing decision here you think......how should i split the four up into two groups,and does it matter?
Oh , and if splitting them like this loses the isolated status, what difference does that make?
analogman ARDX20 15mA
Amazeo (pre set switcher  for above pedal) 30mA
Wet v2 35mA
and a passive mode change switch pedal for Kingsley Harlot v2 ( very low LED only)
Thanks guys  :)
tae be or not tae be
  • TimmyOTimmyO Frets: 7512
    Given it seems you won’t be challenging the current limit of an output, if you get noise, switch them around if not, it probably won’t matter which is with which.
    Red ones are better.
  • The general advice seems to be to keep analogue and digital separate, so Wet and AmazeO on one, the rest on the other.
    But yeah, see if that's quiet. If not, switch them around.
  • HootsmonHootsmon Frets: 15980
