Little Issue with Tremolux
GassageGassage Frets: 30945
edited March 2019 in Amps
I recently grabbed an EC Tremolux 12w 1 x 12 Tweed- which is based on a 5E9
Anyway, with the Tremolo off, and the amp cranked WITH AN EXTERNAL PEDAL- esp a BK Tube Driver, there's a strange occilation going on which sounds almost as if the trem is bleeding into the signal when it's off (but at a high speed).
I repeat, the trem is off, and this isn't a trem sound, more of an occilation....any ideas?
  • FunkfingersFunkfingers Frets: 14568
    Try valve substitution. Begin with the rectifier.
  • RiftAmpsRiftAmps Frets: 3175
    Is the trem actually off, or just set to minimum speed? Does switching it off using the footswitch make a difference?
    Another option is that owing to the terrible lead dress in those amps you have a real oscillation that needs to be addressed, fast.
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
