Telecaster replacement pots audio and linear 250k/500k
Hi Guys,
Need to replace the pots in a telecaster.
Am i correct in thinking that an audio CTS for example is best to use for the volume pot and a linear pot is best used for the tone?
I have read discussions on using a 250k for the volume as the highs from the single coils are already present but use a 500k for the tone?
Interested to know your thoughts!
Thanks in advance.
  • Dead simple for me - 250K log (audio) for both pots on my Tele's, plus 47nF for the tone cap. They just work right for me - no treble bleeds, no 'Gibson 50's wiring', no other tricks.
  • FunkfingersFunkfingers Frets: 14573
    CTS (or better) A250k pot (2 of), .022uF cap. No treble bypass network. No TBX. No No-Load. Maybe, a Fender Greasebucket.
  • RolandRoland Frets: 8754
    Three comments, and three different answers. For a Telecaster with single coil pickups I use 250 audio taper pots for both volume and tone, and either a .022 or .033uF capacitor depending on how bright the guitar sounds. I do use a .001 treble bleed capacitor, but without a resistor in either series or parallel, because I like the tone to get warmer when I turn up for a solo.
  • bbill335bbill335 Frets: 1389
    there are no hard and fast rules. some pickups (or some people) need to squeeze out all the treble they can with 1m pots and a 22 cap. Tradition says two 250k audio pots and a 47 cap.
    I briefly played a late seventies tele ('78 I think) that had 1m pots and it wasn't much more trebly than the parts tele I just put 250ks in (with some mojo 52 pickups, for reference). I would start with the usual 2x250k audio, 47uf cap and adjust depending on what you want more or less of.
  • ICBMICBM Frets: 72630
    Don’t use a linear pot for tone unless you want all the useful range right at the bottom of the turn - always Log. Volume can usefully be either Log or linear depending on how fast you want the volume to roll off below full up.
    500K volume will make a traditional Tele bridge pickup quite shrill, so I would use 250K. A 500K tone will give you slightly more top-end at full up than £250K, but a slightly less useful sweep below that.
  • lineslines Frets: 27
    Some very useful insights, thanks guys!
  • jaymenonjaymenon Frets: 836
    I agree with ICBM.
    Common wisdom is 'Log for volume, Linear for tone',
    It doesn't work for the tone where everything then happens between 0 and 3.
    Log pots for both, if you want a smooth taper on volume and tone pots. The entire range 1-10 becomes useable.
