FS 2003 Fender American Standard Jazz Bass Sunburst RW SOLD
the_crungethe_crunge Frets: 35
edited April 2019 in Basses £
Title sums it up really! As it's from 2003 it has the S-1 switching on the first volume pot allowing for series and parallel which can be pretty handy. I didn't use it much myself so I switched out the knob for a regular one for a more classic look. I'll include spare knob in case you want to do the same.
As you can see from the pictures there some interesting "relic-ing" going on, done by the previous owner and not myself! The bass is in otherwise good condition and plays and sounds great and was recently restrung with Roto Swing 66's. It will be sent in it's original hard case (currently under a bed but if you'd like pictures then just let me know).
EDIT: Forgot to mention that included is a bridge cover, hence the screw holes near the bridge.
I'm looking for £675 £650 which includes UK postage. Get in touch if you'd like any more info or pictures. Thanks for looking !
NOW SOLD
https://imgur.com/cE0hJGW
https://imgur.com/MDCXEwx
https://imgur.com/L9tbkBI
https://imgur.com/KAGbbI5
https://imgur.com/ga9itXs
https://imgur.com/KocVWAh
  • FunkfingersFunkfingers Frets: 14722
    What are the two screw holes between the bridge and the bridge pickup? Has a Roland GK pickup been fitted at some point?
  • What are the two screw holes between the bridge and the bridge pickup? Has a Roland GK pickup been fitted at some point?
    Ah yes should have mentioned, I also have a bridge cover for it, hence the screw holes. The previous owner added the thumbrest and the bridge cover to go for the vintage look, which then explains the 'relic' job!
  • Bump with price drop
