Cheapo Alternative To Boss OC-3 To Make My Guitar Sound Like A Bass
Duppy03Duppy03 Frets: 112
Did Behringer or Harley Benton ever make a clone or something similar?
I want to experiment with splitting my guitar signal into a bass amp playing the bass notes at a lower octive.
The Boss OC-3 looks great but a bit pricey even used
  • JezWyndJezWynd Frets: 6596
    The Valeton OC10 is a copy of Boss OC-2, the analog precursor to the digital OC-3. Simple 1 & 2 octave down functions. Haven’t used it personally but it’s had some decent reviews.
  • Duppy03Duppy03 Frets: 112
    Cheers, will check it out
  • FunkfingersFunkfingers Frets: 15760
    It won't work. The pedal will make your guitar sound like a guitar with an octave down gargling sound following fractionally afterwards. (Nothing wrong with this sound, per se.
    Hey, Hey. My, My.
  • ICBMICBM Frets: 77430
    You need an OC-3 not an OC-2 for this job. It tracks better and you can split the outputs, which you can’t with the 2.
    I tried a Behringer recently and it was poor, as well as not having the split outputs.
    I would buy an OC-3 second hand, so you won’t lose much on resale if it doesn’t work for you.
  • poopotpoopot Frets: 9102
    EHX pog, micro pog or nano pog... Just about the best out there really.
  • TTBZTTBZ Frets: 3046
    edited April 2019
    The OC3 isn't very good for this unfortunately. Or at least I couldn't get it to work for me, the high pass didn't actually work that well. The bass sounds more like a weird synth thing which I didn't get on with. However the Drive mode is a load of fun into a dirty amp. It takes on an octave down fuzz kind of tone and inspired me to come up with a fair few riffs.
    Hey, Hey. My, My.
    I see what you did there, very good. Rock and roll will never die.
    It looks like the OC-3 is the only one I can find with that will do the job with regards only selecting the your top two strings to duplicate as octive down bass notes.
    I can do the signal splitting with another pedal the being able to have it only work within the range of the bass notes is key to what I’d like to try and achieve
    Could a Digitech Trio work?
  • RockerRocker Frets: 5219
    Would it not be easier to buy a bass instead of trying to make your guitar sound like a bass?
    Nil Satis Nisi Optimum
    That's been my experience with most octave down pedals. The only one I've found that did an acceptable reproduction of octave down (and up) was the Bass Whammy pedal. I believe Digitech do the guitar version as a straight pedal minus the treadle - that might be worth checking out - don't think it will isolate certain strings though.
  • meltedbuzzboxmeltedbuzzbox Frets: 10347
    The richochet
    I don't think it does string isolation
  • merlinmerlin Frets: 7143
    I have an ever-so-slightly weirded Micro POG that has the bass on full all the time. I'd rather not throw it away. You can gave it for the price of postage.
  • LonewolffLonewolff Frets: 67
    T-Rex Quint Machine?
  • pintspillerpintspiller Frets: 1026
    Whatever happened to the guy that used to advertise such a pedal in Guitarist. He had a strings pedal too didn't he?
    That’s real kind of you thanks but o don’t think it will do the selective strings thing like the oc-3?
  • robertyroberty Frets: 11254
    The richochet
    Digitech Drop does an octave down, not tried it though
    You can get better tracking with pitch shifting (and tuning) by using the bridge pup and rolling your tone control down, as this gets rid of harmonics from your signal
  • TrudeTrude Frets: 927
    I use an OC3 on acoustic to achieve what you're after (I don't need a bass amp though as it all goes through the PA).  It doesn't have true string isolation, but you can define the note below which the effect kicks in.
    Sound-wise I'd say it's okay if used in moderation.  It won't be convincing if you want it to literally be at the level you'd normally expect to hear bass guitar in a rock band setting.  You also have to play to the pedal - you can't just bash out a normal rhythm part and expect it to magically create a decent bass sound.  If you can pick out clean bass notes and limit strummy stuff to the top few strings then it works okay.  For single note riffs it should work pretty well.
    To improve much beyond the OC3 I think you'd need to look at a specific pickup system like the Submarine that can isolate and process the bottom two strings independently.  Every so often I check to see if anyone's made an improved version of the OC3 but all the octave pedals I find just act on all frequencies, which would sound terrible for chords.  I live in hope...
    Some of the gear, some idea
    Trading feedback here
    @merlin pm sent
  • TeetonetalTeetonetal Frets: 7939
    I have been down this road with the oc3. Nice idea but it didn't work for me, I could never get the Freq cutoff to be limited enough and it just sounded too messy.
    Works best if you are doing fingerstyle. Jon Gomm gets great sound from it.
